Sennheiser MKE 300 Shotgun Microphone WITH HDR-FX1 - HISS AND LOW LEVELS at DVinfo.net
Old October 18th, 2005, 06:31 PM   #1
Sennheiser MKE 300 Shotgun Microphone WITH HDR-FX1 - HISS AND LOW LEVELS.
just wondering if anyone has this mic and is experiencing low levels and a hiss sound...
if not i must have got a bad one...
thanks
joel
Joel Corral is offline   Reply With Quote
Old November 7th, 2005, 11:14 AM   #2
I have had a similar problem, but I think it had to do with the Beachtek box I was using. Has anyone else experienced this?
Bill Piedra is offline   Reply With Quote
Old November 7th, 2005, 12:04 PM   #3
I've got it for my hd1, but the only time I encounter a hiss is when the battery is low, that's about it. The red indicator light flashes when you turn it on, and I usually do a test record and play back the audio to see if it sounds decent, if I hear the hiss, time to swap the battery. Other than that, the mic is ok.
Carlos Rodriguez is offline   Reply With Quote
Old November 10th, 2005, 12:00 PM   #4
well i returned it and got a RODE video mic... super pleased so far.
joel
Old November 10th, 2005, 05:04 PM   #5
I've found that putting the audio to auto tends to make it really quiet. As in -30dB... At least it's been nice and clean for me so I can boost it as much as necessary.
Mark Utley
Mark Utley is offline   Reply
