Buying 2nd hand Z1P with strange hours meter at DVinfo.net
Old July 14th, 2012, 07:06 PM   #1
Hi all!
I am in the middle of making a transaction for a Sony Z1P with extras for $2000.00
I have the camera at home and am assessing it to make sure it's totally functional. Everything appears to be fine, except the hours meter looks strange to me;
Operation = 163x10H
Drum Run = 1x10H
Tape Run = 1 x10H
Threading = 5x10
As the previous owner was a cinematographer, I don't understand why last three figures are so low.
I saw a separate camera on eBay (Aus.) described with "low hours" as;
Operation = 110x10H
Drum Run = 16x10H
Tape Run = 10x10H
Threading = 27x10H
so I'm guessing the hours on mine are pretty decent, but why so strange?
I will ask the seller as well, but could it be that he has replaced parts (all the internal mechanics sparkle like jewellery, as I'm told they should), essentially bringing their figures back to 0, or is this a camera to steer clear of as the meter may have been tampered with?
Thanks very much for your time and help!
art is what you can get away with - Andy Warhol
Jamie Brooklyn is offline   Reply With Quote
Old July 14th, 2012, 07:47 PM   #2
Re: Buying 2nd hand Z1P with strange hours meter
Perhaps the camera was only used without a tape for a live switched setup or only with external recording. Ask the seller and see what they have to say about the numbers!
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old July 15th, 2012, 12:12 PM   #3
They've probably had the deck section or heads replaced.
Old July 15th, 2012, 09:32 PM   #4
Thanks for the info. Would there be any issue with the deck or heads being replaced? Or would that be beneficial?
Cheers
Old July 16th, 2012, 12:32 AM   #5
Some sources say that 1500 hours is the recommended head replacement interval, so it sounds about right.
Old July 17th, 2012, 04:50 PM   #6
Cheers Adam,
Spoke to the seller. He only used it a few times, and the user before that used it for live corporate events, recording externally to a vision switching system.
Thanks for the replies. :) Wanted to make sure it all added up.
Old July 17th, 2012, 05:36 PM   #7
Frankly I like my version better.
Old July 17th, 2012, 06:08 PM   #8
Do I get a prize for guessing correctly?! ;)
Old July 21st, 2012, 11:53 PM   #9
LOL! I award you an immense THANK YOU as your prize Nate!
On the next vid I make I'll be sure to thank you with a credit and let you have a copy :)
