HC1/A1 as "Dubbing/Transfer" deck? at DVinfo.net
Old August 16th, 2005, 05:35 PM   #1
Has anyone tried to playback HVR-Z1 HDV tapes through the HC1/A1? If it works, the HC1 might make a very convenient and affordable "dubbing/transfer" deck. Will it work?
Jim
Jim McCrain is offline   Reply With Quote
Old August 16th, 2005, 06:06 PM   #2
Jim
As long as they're the same format (ntsc tape for NTSC hc1) they play just fine. I've played Z1 tapes in both the HC1 and the A1u.
Keep in mind too, the z1 can do DVCAM, which the HC1 can't read.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old August 16th, 2005, 06:41 PM   #3
Thanks for the quick response. That is precisely the info I was looking for. I should have made it clearer, though, that I was only looking to use the HC1 as an HDV transfer unit. I can use one of my other DV cameras for transfering DV, and I haven't shot any DVCAM yet. (That format would be edited somewhere else, anyway.)
Guess I'll get one of the HC1's just to spare the heads on my Z1!
Cheers!
Jim
Old August 16th, 2005, 07:00 PM   #4
Wow, is that true? It would be a big departure for Sony. Even their inexpensive one chip cameras can read DVCAM tapes, although they cannot record in that format....
Old August 16th, 2005, 07:10 PM   #5
You know, Boyd, I didn't test that, so I shouldn't have stated it as fact. I don't know if it can or can't. It may well be able to read the DVCAM tape format, and I don't have an HC1 here to test. The A1U reads it just fine...but... not sure about the DVCAM now that you mention it.
Old August 17th, 2005, 07:14 AM   #6
How about something like this from JVC, which is their portable HDV deck.
JVC CU-VH1US-P
http://www.bhphotovideo.com/bnh/cont...goryNavigation
Now I don't believe that it can play DVCAM, but it can still play Mini DV if recorded in that mode.
I thought that this might save wear and tear on the payback heads.
Michael Liebergot is offline   Reply With Quote
Old August 17th, 2005, 07:23 AM   #7
I'm pretty sure that JVC deck can't grok Sony's 1080i HDV....
Old August 17th, 2005, 11:41 AM   #8
Barry Wan Kenobi
Correct -- none of the JVC decks can play back Sony 1080i HDV. Also, that particular deck can't play back ProHD's 24P format either.
Barry Green is offline   Reply
