Need suggestion on a Microphone
I have an FX 1 with Beachtek Dxa-Fx adapter and an azden Sgm-1x and would like to get a better sound. I'm on a budget and can't go as far as me66/k6 way. Can someone recommend between AT897 and NTG-1 or 2? Thank you in advance.
KC. |
NTG-2. I personally love the Rode short shotguns. I prefer them over the ME66, in fact. The ME66 sounds, as someone else said, too brittle and bright.
Unless the Beachtek provides phantom power, you'll want the NTG-2 because it is battery powered. |
Yep the NTG-2 sounds better .. and when you come to sell it sometime waaaaay in the future you'll have more chance because of its battery option :)
A customer call RODE get is from folk who forget to remove the battery when they start powering the NTG-2 with 48 volts .. and the battery goes flat and some leak. That's not covered by warranty :( Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
Another vote for the NTG2. I love mine.
I bought it from BandH with the shock mount, and McGivered it to mount on my Z1. Helped a lot with the handling noise, which I found bad on the Z1. Check the little screws on the barrel once in a while. They can come loose over time. |
#5 | |
#6 |
I caught mine before losing the screw, but it was a close one. Here's the mount I made with the end of a broomstick, believe it or not. Works great. I painted it after this picture.
#7 |
You guys are a great bunch. So NTG-2 over AT897?
I bought the Azden a while back before I knew about this forum and only based on a price, for some reason I never hear anybody recommending Azden at all, never see anybody using it either, I can't really complain about the one I have because I never compared it with another brand, but is the Rode really that much better? Also, Edward, do you have a panny and fx1/z1? If so, when you do editing, do you find the picture profiles being hard to match? My partner has a dvc30 and when we shoot with two cameras his colors look way brighter and punchier vs fx1's dull and flat colors, what's the solution to this? |
#8 |
Wow, topic died on the word Azden?
:( so, nobody owns azden? Is it that bad?
