zu1 and nano flash at DVinfo.net
Old March 10th, 2010, 01:43 PM   #1
zu1 and nano flash
Anyone using Nano Flash with the Zu1? If so how does it work and is there an improvement on the quality of the image?
Ronnie Martin
Ronnie Martin
Kato Video
Last edited by Ronnie Martin; March 10th, 2010 at 01:46 PM. Reason: mis spelled word
Ronnie Martin is offline   Reply With Quote
Old March 11th, 2010, 09:11 PM   #2
I believe the Nano only accepts HD-SDI or HDMI inputs. The Z1U outputs neither...so I suspect unless the is a working component-HDMI converter box in the mix, you'd be hard pressed to use the Z1U & Nano together.
Bill Ward is offline   Reply
