Finally had enough at DVinfo.net
Old July 2nd, 2005, 09:28 AM   #1
Finally had enough
Just spent the last 10 days editing two videos, color corrected, levels adjusted, noise reduced, and 5.1 surround effects applied.
For the grand preview I get buses with window posts scattered through out, a jumping fish with three bills, rods sticking straight up with the jaggies. Oh sure all the locked down static subjects look great, but movement is 99% of my subjects. This just isn't working.
OK, feel better now, guess I will go back to the XL1 S.
Jim
Sony FX1 - AspectHD - Vegas 6 - AVI Uncompressed - Procoder, preset DVD Master - DVD Architect
Jim Montgomery is offline   Reply With Quote
Old July 2nd, 2005, 10:11 AM   #2
could you post these vids? i'd like to see what's so bad.
Eric Gorski is offline   Reply With Quote
Old July 2nd, 2005, 03:52 PM   #4
Bad Day?
Sound like you having a bad day Jim!
Did you do it like you have always done, down-convert to DV from HD and with the same settings on the Sony? Didn't you use to use Adobe Premiere Pro? Did you try burning them or is this just off of the time-line? Just thinking, you have a hot computer but maybe not quite keeping up?
Anyway, good luck with it and have a great 4th!
Mike
Mike Teutsch is offline   Reply With Quote
Old July 2nd, 2005, 04:04 PM   #5
CTO, CineForm Inc.
The double images you are seeing is because you are deinterlacing the frames and presenting to fields summed together -- Vegas and Premiere with Aspect HD will present interlaced images this way only while previewing (Aspect HD gives you for option to turn the de-interlacing off so you can see the interlace fields in all their glory.) In either package, when you do your final HD export this should not be present. The shots you uploaded are 960x540 (half horiz. half vert from 1920x1080) -- to create a 960x540 from a 1080i source will require deinterlacing -- you need to be careful with the deinterlacing you apply OR shoot in the CineFrame modes and forget all about interlacing (it would be nice that interlace didn't exist.) With this long holiday weekend it might be hard to get good support, but contact your NLE tools vendor Tuesday to get the help you need. Your pictures otherwise look very good.
Old July 2nd, 2005, 04:04 PM   #6
If I were to take a guess, it would be that your shutter speed was not fast enough. When you set iris and gain to manual, did you also set the shutter speed to at least 60? Or higher?
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old July 2nd, 2005, 05:11 PM   #7
David
It actually looks good(?) in preview, it really falls apart when I burn it to DVD.
Steven
Actually the shutter speed was set to 250.
Actually I have had a bad day Mike, I guess I was expecting the DVD images to look as good as it does on the camera LCD.
Old July 2nd, 2005, 05:58 PM   #8
OK, my guess was way off. Are you deinterlacing for the DVD? Losing resolution at the larger frame size isn't much of a problem when you are using such a small frame size for the DVD.
Steven Gotz
Old July 2nd, 2005, 07:20 PM   #9
Forgive my ignorance, I think I know what you mean, after watching that wonderful "RAZOR SHARP" HD video, then when you down-rez it to SD it looks really soft right?
If so, yep thats exactly what i've experianced (using wmv sample files various FX1/Z1 stuff found from the web),
one thing that I tried just 3 days ago was this little trick:
In the HD timeline go add a sharpen filter and apply hard, now this will make it look nasty (i know), NOW down-rez to SD DVD, voila the down -rezed should look ALOT sharper than before (granted it ainted gonna exactly the same as the HD source, but it will be a whole lot better).
Another thing you can do is down rez using some really expensive stuff the BBC used (in their FX1/Z1 experiments) an Snell and Wilcox thingy-ma-gig, they reported great results, they concluded that you have to use expensive donw-rezers to get good results (perhaps Vegas native down-reser aint that good).
Anyway try out my little trick and tell me how it goes
(say on a 30 second test clip, and do an A/B type test, you know apply the filter to say the clip, then put the same clip without the filter and down-rez the two clips together)
Anhar Hussain
PS, just forgot to mention , you may want to actually play around with the amount of sharpen you use (to get best results, i said use hard, because thats the only setting i attempted and didnt get to try other levels due to lack of time)
Anhar Miah is offline   Reply With Quote
Old July 2nd, 2005, 11:17 PM   #10
Any kind of deinterlace attempt on 250fps footage sounds like it would not work well to me. It is the same effect I get when I tried using the 30fps mode to get a frame doubling effect that sony use to give me with my vx-2000.
The vegas 6 24p widescreen dvd render template works well for me and gives very smooth results. But I always shoot at 60fps unless there is a reason to shoot at another speed. And it had better be a very good reason...
Did you choose upperfield first for all of the work?
Canon C100, 5D3
Jeff Baker is offline   Reply With Quote
Old July 3rd, 2005, 11:53 AM   #11
He said his shutter speed was 1/250. The frame rate continues to be 30fps regardless of the shutter speed. You mean any attempt on a shutter speed of 250, right?
Augusto Manuel is offline   Reply With Quote
Old July 3rd, 2005, 12:48 PM   #12
1/250 shutter right, not fps. my bad.
I am not going to do the math, but deinterlacing 1/60 to 30p should be much easier.
Canon C100, 5D3
Old July 4th, 2005, 12:18 PM   #13
Et all.....
I did not deinterlace anything that I know of. I captured and then converted the m2t file with AspectHD, split scenes. Did the editing in Vegas 6.0 and rendered as avi uncompressed. Took this to Procoder and converted using MPEG2 - DVD - Mastering Quality preset, throughout the whole thing I did not mess with any of the preset(s) settings. Burned a DVD with DVD Architect and ended up with poop.
Jim
Old July 4th, 2005, 12:27 PM   #14
gotcha, I see. The field settings in procoder need to be set to upper first if it does not auto recognize it that way. If it did default to upper, then I would guess a field got set to lower somewhere in your workflow.
Canon C100, 5D3
Old July 4th, 2005, 12:43 PM   #15
CTO, CineForm Inc.
Jim,
Somewhere in the workflow something is scaling the image incorrectly. Converting HD 60i to SD 60i while converting field dominance from upper to lower is not easy. Unfortunately I can't determine if it is Vegas (my copy will not start today -- it has taken the 4th off) or Procoder that is at fault (I don't have that.) If you exported uncompressed in HD from Vegas, try scaling to SD in the export or if you did that try an HD export. One of the tools will need to scale HD to SD, I'm hoping only one them has it wrong.
