Accessory mount on handle for FX1 at DVinfo.net
Old May 26th, 2005, 01:23 PM   #1
I saw a picture of an additional accessory mount that someone was selling for the FX1 that attached to the handle, but for the life of me I can't find it anywhere. Does anyone know where I can find this thing? It had two halves, one on the top and one on the bottom of the handle that screwed together to make another mount point for shotgun mics, etc. I would like to use this to mount my SGM-1X shotgun mic so that it doesn't stick out so far in front of the camera.
Also, I was wondering if anyone makes an adapter so that I could mount a shotgun on the right of the LCD panel like the Z1. Thanks.
Roger Mason is offline   Reply With Quote
Old May 27th, 2005, 11:36 AM   #2
handle
mini HDV Handle Bracket
For Sony HVR-Z1U HDV Handycam's
The mini HDV Handle Bracket is a natural extension to our line of PCI Heavy Duty Broadcast Camera Handles. The Sony HVR-Z1U-HDV Handycam is an amazing piece of technology for the documentary, music video and the extreme sports market.
This mini HDV Handle Bracket handle is perfect for adding extra mini LCD monitors, audio transmitters or anything you want to add to your camera.
The mini HDV Handle Bracket is flat on top for direct mounting of mini SteadyCam's for low angle set up's. You can also mount it to a fluid head that is upside down on a mini jib for low angle shooting, or just use a mono-pod for those quick low shots you want.
This bracket is tough enough to support up to 77.16 lbs (35 kgs) and is made of tough polymer plastic with 2 x 1/4" and 2 x 3/8" brass threads molded directly into it. This is an ultra light and tough bracket that weights in at 1.6 oz or 45 grams.
Includes 2 piece bracket with 4 mounting screws and Hex key for mounting
$225.00 USD
NAB Launch Special
$198.00 USD
Volume Pricing
Also works for the
Sony FX1-HDV Camera
When your front thread is busy, add more equipment to your
camera handle
Use a mono-pod for low
angle shooting
Mount camera to mini jib with
fluid head upside down for
smooth low angle to
head height shots
Prices subject to change without notice
[ Home ] - [ Info ] - [ Community ] - [ Products ] - [ Contact Us]
Copyright © 2002 VFGADGETS.com
John Lutz is offline   Reply With Quote
Old May 27th, 2005, 07:01 PM   #3
Go Cycle
I got mine from Al-Art Video for 40 bucks...attaches right to the handle.
If I can figure out how to post a picture from my computer I would.
Lou Bruno
$225.00 USD
NAB Launch Special
$198.00 USD
Volume Pricing
Also works for the
Sony FX1-HDV Camera
camera handle
angle shooting
smooth low angle to
head height shots
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old May 28th, 2005, 09:21 AM   #4
Thanks guys, that's exactely what I was looking for. I want to use it to attach my Azden 500UDR receiver to it, do I need to get some kind of additional hardware for that, or does it come with those kinds of things?
