HDV viewer?? at DVinfo.net
Old May 15th, 2005, 12:11 AM   #1
HDV viewer??
Are there any machines out there to view the HDV tape other than the camera itself?
if possible, other than the Sony player that coasts about as much as the FX1 itself.
Shawn D. Caple is offline   Reply With Quote
Old May 15th, 2005, 08:19 AM   #2
Sony has the M10 U deck, which is battery powered or AC powered. It will play either the JVC tapes or the Sony tapes
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old May 15th, 2005, 11:01 AM   #3
Barry Wan Kenobi
It'll play JVC tapes, but it won't let you digitize the JVC tapes, will it? You can only play the Sony tapes out through the firewire; you couldn't use the Sony deck to digitize JVC tapes. It'll play the JVC tapes and let you view the analog output, but not through the firewire...
Barry Green is offline   Reply
