How to Convert 1394 to DVI, VGA or Component at DVinfo.net
Old April 13th, 2005, 06:07 AM   #1
Is there a Firewire to Component (Stand Alone) Device Available
I just received my FX1 and Dell Monitor yesterday. The FX1 will record in HDV, and at the same time, send a SD 3.4 signal through the Y/C connector (allowing me to record on a DV deck that accepts standard size HDCAM cassettes).
Only thing, though, I'm unable to monitor the HDV signal using the component out on the FX1, because it defeats the Y/C output. Apparently these two outputs are combined and you can only use one or the other.
There is a solution, however. When I connect the firewire output of the FX1 to a JVC 3k D-VHS deck and then use the component out of the JVC, I'm able to monitor the HDV signal. It also has no effect on the recordable SD output.
Unfortunately, the D-VHS deck will not record the video from the FX1 without severe pixilation, but does pass through a clean signal for monitoring.
Is there a simpler, inexpensive device available that will convert the firewire signal to component so I can monitor without the D-VHS deck?
Thanks you-all,
Ben
Ben Hardy is offline   Reply With Quote
Old April 13th, 2005, 07:25 AM   #2
Until you said "Inexpensive..." the Convergent Design HDV Connect is the right answer. It offers DVI out, component out, SDI out....but it's not cheap.
www.convergent-design.com if you're interested in chasing down more information.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 13th, 2005, 07:52 AM   #3
Thank you, Douglas for your response.
Actually, the JVC deck cost me $289. I'm trying to find something smaller, so I won't have to lug it around when I do on-location gigs.
Ben
Old April 13th, 2005, 12:14 PM   #4
Barry Wan Kenobi
They've made inexpensive standalone devices like that for DV, 1394-to-component... don't know of any for HDV 1394-to-component...
Old April 14th, 2005, 07:18 AM   #5
ADDENDUM TO A PREVIOUS POST:
I've just received a Dell W-1900 Monitor. It has DVI, VGA and Component Inputs. I'm trying to convert the 1394 output of a FX1 to one of these inputs, so I can use the monitor. I'm unable to use the "component out" of the FX1, as I'm recording a SD signal through the Y/C connector.
Is there any converter box under $500 that will do the job?
Ben
Old April 14th, 2005, 08:18 AM   #6
http://www.videoguys.com/dac.html
why not just split the y/c?
- shannon W. Rawls
Shannon Rawls is offline   Reply With Quote
Old April 14th, 2005, 08:41 AM   #7
Assuming that the firewire output is SD?...
You could use a DVD recorder with firewire input and component output. I do this with a Sony RDR-GX7 and it works very well. DVD recorders are getting a lot cheaper, so I think you can do this for $500 and have the recorder as a bonus.
Old April 14th, 2005, 09:14 AM   #8
Hi Shannon,
Thanks for your reply.
I'm afraid that particular unit would not pass the (1394) HDV signal through from the FX1 to the monitor, without reducing the video to SD NTSC.
I need to monitor the HDV video.
Thanks again for your response,
Ben
Old April 14th, 2005, 09:41 AM   #9
Why not use the above solution in reverse...
ie. pass an SD Firewire signal thru the DVD-recorder to convert it to the Y/C and then you're free to use the (HD) component out straight from FX1 to monitor.
I think this should be possible ... anyone confirm this ?
Of course, the DVD-recorder could be substituted with a small mini-DV camcorder set to DV-in - a very portable option - which also allows you to backup your shoot (at SD quality and PCM audio).
Play to Learn,
Learn to Earn,
Earn to Play...
Dave - Broader Pictures
Dave Elston is offline   Reply With Quote
Old April 14th, 2005, 09:41 AM   #10
Hi Boyd,
Actually, the 1394 out from the FX1 is HDV. I can use a JVC D-VHS recorder's 1394 input and take the output from its' component out, to the monitor, and get HDV video.
I'm just trying to avoid lugging around the JVC when I shoot on-location. If I can find something smaller, that would be so much easier.
Ben
Old April 14th, 2005, 01:09 PM   #11
Hi Dave,
That's an excellent suggestion!
I'll have access tomorrow to and old Sony device that accepts DV 4 pin 1394 IN, and converts to S-VHS OUT. The manual of the FX1 says you can output 1394 in SD. If I can keep the aspect ratio at 4.3, I'll be in business.
Thanks to all you guys for helping me. This Forum's the BEST!
Ben
