Thread Tools
Search this Thread
Shutter vs. Cineframe ?
Hello :)
I've just got my Z1 yesterday and doing all kinds of tests right now. So the first thing is wonder is: Is there a difference between cineframe and normal mode with shutter set to 25 ? If not I would prefere 25, as it's then more light sensitive. Thanks ! Peter |
You'll find that there's more inter-frame blurring with the shutter set at 1/25th.
Robin |
Isn't that good ? For a Filmlook ?
And is it then also deinterlaced ? Should be. Or how can you get 50 frames if the shutter opens only 25 times. |
<<<-- Originally posted by Peter Rixner : Isn't that good ? For a Filmlook ?-->>>
No, film camera shutters are only open half the time (for 25fps, that means, for a 50th of a second). At video slow shutter 25th/sec, there is twice the motion blur that a film camera would have. <<<--- And is it then also deinterlaced ? Should be. Or how can you get 50 frames if the shutter opens only 25 times. -->>> The FX1 deinterlaces slow shutter the same way as CF25, it just drops a field, and repeats the first field in as many subsequent fields as is needed. |
