Using FX1 w/ mixer at DVinfo.net
Old February 19th, 2005, 03:01 PM   #1
Using FX1 w/ mixer
I have a Z1 and a friend of mine just got an FX1. We are going to use these cams on the same shoot so I am planning on using a mixer for his cam to hook up XLR mics.
If I was to use the Sound Devices 302 mixer would I need to use a pad into the mini jack on the FX1?
Also, are there any drawbacks/limitations I need to be worried about when using an FX1 w/ mixer as opposed to just using another Z1? If there are I might just rent another Z1.
Greg Jacobson is offline   Reply With Quote
Old February 19th, 2005, 03:32 PM   #2
isn't the limiter always on with the FX1?
Sean M Lee is offline   Reply With Quote
Old February 19th, 2005, 03:43 PM   #3
I don't believe there is a means of disabling the AGC on the FX1, but I could be incorrect, since I don't have one.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 19th, 2005, 03:45 PM   #4
<<<-- Originally posted by Sean M Lee : isn't the limiter always on with the FX1? -->>>
Yes, that is one issue. I am more concerned about hooking the mixer up the the FX1 because I have read that with some mini DV cameras you have to pad down the line into the mini jack.
Old February 19th, 2005, 05:11 PM   #5
depends on the mixer, too.
some mixers have line level or mic level out...make sure yours is set correctly.
Old February 19th, 2005, 07:28 PM   #6
I beleive your mixer can be switched to send a "MIC" level signal rather then Line Level.
Either way, In the FX1, I think you can go in the menu and switch it from MIC to LINE for the levels. So you should be all good.
- ShannonRawls.com
Shannon Rawls is offline   Reply
