#46 | |
I love the Sony hard case too!
I have the 'same' aluminium box designed originally for the VX2000. Just had to cut out the base and top inside lid supports for my Z1 and will use for most transport. Also have a Portabrace backpack with internal dividers and velcro straps originally bought for my (sold) PD150. Quite bulky but more practical for outdoors hiking that I am gearing up for. Space for water and food. :) Richard
Richard Entwistle Hong Kong |
#47 |
15 years ago I routinely sent my tube camera down the airport shute in a big padded hard case. And I still had to register it when I landed. Those days are long gone. The protocol I followed for the next 11 years as a network Sony Beta-cam chip photog was to place our cameras in the over head compartment of the airplane with only a pillow to protect the lens on takeoff. No bags or cases, and I never had a problem once I hit the ground.
I am now a freelance Panasonic DVX-100A shooter and rather than buying a separate bag for the camera and another for essentials, I bought a Porta-Brace CAR-3 from Adorama, SKU# PBCAR3 for $180. It holds the cam, batteries, audio equipment, tool kit, etc. It has velcro dividers to customize the inside space and has four outside pockets. And it should fit nicely into a plane's overhead compartment. I wouldn't hesitate to fly with this bag. Hope this info is helpful.. |
#48 |
I flew quite a bit the last 10 days with my Portabrace Cargo 2. It fits nicely into the overhead compartment on all the planes - large and small - that I flew in. I help all of my gear as well as my still camera - a Nikon D100 without any problems.
As a side note...as I was going through security in SLC I followed some folks who were travelling with an FX1 in a Sata soft bag. I thought it odd that we both had HDV cams. At one point I contemplated gate-side checking the case because of a very full flight. I feel confident that it would have protected the camera and other contents. I don't think I would do a curb-side or ticket counter checkin, but the gateside check in seems to be less abusive. |
#49 |
Which is smallest reasonable Pelican case for the FX-1?
My love of Pelican hard cases 'reawakened' the above older thread.
After reading through the thread, I see that many have provided their opinion of which cases are best for the FX1 (leaving me even more confused). So, to narrow things down a bit, which size Pelican is the smallest that will reasonably accommodate the FX-1 (or Z1U), batteries, and a few other misc. small accessories? Thanks in advance, --Jim |
#50 | |
1520 Outside Dims. 19.12" L x 15.43" W x 7.56"H 1520 Inside Dims. 17 7/8 x 12 3/4 x 6 3/4" 1527 Interior Dims 17 1/2 x 12 1/2 x 6 3/8" see: http://www.casesbypelican.com/app-1520.htm I really wish that pelican made a case that had more depth (or was equal in two dimensions, like 9"x9"x18") because the depth is always the problem dimension on the smaller cases, and the weakest part of the case is the largest surface and that is where you have the least padding for the camera. The Kata Shell-03 (CCC-2003) is 16.5Lx10.6Wx7.9H which fits the FX1 well, but it's not like a Pelican (e.g. it could be crushed, but it's much stiffer than a soft bag). The great thing about the Kata is that it looks so small compared to a Pelican case. |
#51 |
check: alphatron.nl they have a seperate division called camrade.
Upon my inputr they made a special bag for a z1 with a chrosziel mattebox attachhed. . you can use it as a normal bag in you hand. over the shoulder. and also as a rucksack! |
#52 |
Just got myself a FX1, and am looking into buying a case for it. I'm not planning on bringing it on a plane or anything, I just need something that will store the camera and some small accessories. So I'm not looking into anything expensive.
Does anyone have experience with a Vanguard Hard Case? Thanks! |
#53 |
i am using a Lowepro Magnum AW for my FX1 and it fits just fine. I love Lowepro bags!
#54 |
Can anyone confirm the Pelican 1520? Shawn put up the specs that make it look like it should, but has anyone actually tried it?
#55 | |
think my FX1 will be coming in next few days and I used a 1520 for my VX2100 |
#56 |
well it will not fit in standing up which I figured
it will fit in laying on its side I have he divider set not the foam and got it to work OK ?? a bit taller case would be ideal for this camera though I can snap a few shots and post it if anyone wants to get a idea how it fits in and what room is left over |
#57 |
I just got the Pelican 1520 as well. Fits the camera, charger, tapes, extra battery(s), and remote easily. I love the durability of it.
#58 |
I have to move a lot in Manhattan, on feet and in buses/subways/cabs.
Bag is the solution for me. I used to have a large gym bag with lots of foam insulation for my Z1, for two reasons: - pro bags induce theft; - they cost a lot. But recently I came across Kata MC60 and just couldn't resist - it holds everything, including the external mic assembly, filters/lenses/batteries/tapes/lens cleaning solutions/charger, my 35mm adapter, and has space for some more - all at $99 and sized smaller than my gym bag. B&H seems to have discontinued it and moved the last (demo?) piece to their Used dept. - where I happily picked it up :) Original price, I think, was around $150. |
#59 |
I've mostly been a case guy, but have recently discovered the joy of bagging it for those short trips or carry-ons. I just finished a review of the new Petrol Camporter bag if you're interested in how it works for us.
Read it here
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#60 | |
Did you resolve this or did TSA just give you some explaination in another language which amounted to, tough luck.
What happens if I push the 'Red' button? |
