Audio Monitoring while you shoot? at DVinfo.net
Old December 14th, 2004, 09:22 AM   #1
No Audio Monitoring while you shoot??
After seeing the camera at the DVexpo West last week....
Correct me if I am wrong...but a major blow to the Z1 (for me atleast) is...The camera has NO audio meters on the screen during shooting. To check the meters, you have to hit a button and it pops up the meters with a gray shaded area over the screen. But if you wish to see the meters on your video assist monitor while they shoot, say for instance in the lower left hand corner, so you can watch the levels.....you can forget about it.
But maybe I am wrong...I hope I am.
- Shannon W. Rawls
Shannon Rawls is offline   Reply With Quote
Old December 14th, 2004, 12:22 PM   #2
If you put the camera in manual audio mode instead of auto, the meters will appear on the LCD display and the video output if you have the DISP OUTPUT menu set to V-OUT/PANEL.
This display is full-time on the lower right portion of the LCD and is different than the "STATUS CHECK" meters you are talking about.
Mike Tiffee is offline   Reply With Quote
Old December 14th, 2004, 02:14 PM   #3
Much appreciated, Mike -- thanks for setting us straight on this.
Old December 14th, 2004, 04:38 PM   #4
The title of this thread should be edited to reflect that there is audio monitoring available--otherwise prospective buyers are going to get the wrong idea.
Patrick Williams is offline   Reply With Quote
Old December 14th, 2004, 04:50 PM   #5
Good idea, Patrick, thank you.
The title of this thread has been changed from "No Audio Monitoring while you shoot?" to "Audio Monitoring while you shoot?"
Old December 15th, 2004, 08:38 AM   #6
MPS Digital Studios
I can verify this, as well. Of course, the FX1 goes up to 0 (being the highest level) and sound is recorded on two tracks, even with a BeachTek adaptor and one channel plugged in.
heath
My Final Cut Pro X blog
Heath McKnight is offline   Reply
