upper field first when capturing from HDR-FX1?
should i choose upper field first when capturing from HDR-FX1?
is that the correct process? or does it matter if i choose upper or lower field first? thanks joel |
Yes, all flavors of interlaced HD are upper field. Makes things simple to remember.
Exception would be when using CF30 and CF25 material, you can treat it as frame, or progressive. Regards, Jim Arthurs |
thank you so much jim.
that explains the problems i was having when i would playback the HD footage after i down converted to 480i. i was getiing major interlaced distortion. thanks again!!!!!!!! |
