Another HDR-FX1 Preview. at DVinfo.net
Old September 27th, 2004, 10:20 PM   #1
Can be found here:
http://www.mindspring.com/~d-v-c/
Tre Stylez is offline   Reply With Quote
Old September 28th, 2004, 08:01 AM   #2
So, would using CineFrame 30 mode result in 50% loss of resolution or only 25% like the Canon GL2?
Daniel Broadway is offline   Reply With Quote
Old September 28th, 2004, 10:57 AM   #3
I don't know about the resolution question as refer with the GL2, but
i was wondering about the remark from the above website:
"Although the HDR-FX1 looks quite large, it weighs only 2kg (4.4 pounds). Analog component output (only), i.LINK (HDV and DV), and a LANC port are some of the connectors supported by the FX1. Although a 720p30 tape can be played and output via component analog—the 720p30 Transport Stream cannot be output by the FX1’s i.LINK port."
Thats too bad, i was hoping that the signal could be exported directly to a laptop without compression. Does anyone know more on this idea? Could the output be limited by the cable or by the preprocessing? -a.
airmac
Aaron Mcilvain is offline   Reply
