z1 and infinity button.When to use it? at DVinfo.net
Old August 13th, 2009, 02:53 AM   #1
When u suggest to use the infinity button?
Thx and sorry 4 da quest
Old August 13th, 2009, 08:27 AM   #2
When you don't want to focus on anything nearer than 30ft (10m)
Dugi Barr is offline   Reply With Quote
Old August 13th, 2009, 08:38 AM   #3
I've used it to ensure my shots of the ground don't have the camera focusing on the plane's (scratched) window. I've also used it to give a 'snap' pull focus. I'm filming a daisy in telephoto close-up and -zip- I'm then focused on the picnic makers in the distance and the daisy blurs.
Old August 13th, 2009, 11:50 AM   #4
That's a great idea
Aric Mannion is offline   Reply With Quote
Old August 13th, 2009, 12:14 PM   #5
Personally I don't trust any of the autofocus functions on the Z1 and always go with manual. Also (IIRC) the infinity setting does not work properly with a telephoto adaptor lens which I often use for performances.
Old August 13th, 2009, 08:37 PM   #6
What the heck is the "infinity button"? You mean when you manually focus to show the infinity icon on the LCD?
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old August 13th, 2009, 09:57 PM   #7
The bottom position on the FOCUS slider switch. Top is AUTO, middle is MAN, bottom (spring-loaded; snaps back) is INFINITY.
Old August 14th, 2009, 04:36 PM   #8
I'll be damned. I've had this camera over three years and never noticed that. You learn something new everyday.
Thanks, Adam!
Old August 14th, 2009, 05:08 PM   #9
That's a feature which dates all the way back to the VX-2000 on Sony cameras... probably even the VX-1000!
Old August 14th, 2009, 08:03 PM   #10
Doesn't say much for my powers of observation... And I've actually read the manual several times.
Let's just say it's a feature I've never needed. Yeah, that's it!
