SD vs down converted HD - Page 3 at DVinfo.net
Old July 12th, 2009, 05:03 PM   #31
Originally Posted by Boyd Ostroff View Post
... all standard definition wide screen 16:9 is anamorphic...
That's not correct. Wide screen was first achieved by cropping SD and putting black bars on the top and bottom. As they advanced they switched to anamorphic which used all of the vertical resolution by squeezing the image when filmed, then was expanded by the dvd player. This then was called "true" wide screen.
Old July 12th, 2009, 10:33 PM   #32
I believe what Boyd is referring to is that all 16:9 SD DV is RECORDED as "anamorphic", which is a "new" take on the original filmic process of placing a "squeezing" lens on the camera and a "stretching" lens on the projector.
By this I mean that REGARDLESS of whether one has native 16:9 sensors or a centre crop of a 4:3 sensor is performed (lowering resolution), BOTH are recorded to tape the same way which is writing the information to a 720 x 480 frame size (ASSUMING NTSC) with a pixel aspect ratio conversion so that during play back, the 720 x 480 (which is NOT 16:9 if you do the math...) BECOMES 16:9.
Of course, Pete knows this and my dissertation is solely for the benefit of future readers.
Old July 12th, 2009, 10:34 PM   #33
Actually, the process was to take a 16:9 shaped "bite" out of a 4:3 image and then stretch that vertically to fill 4:3 frame and record to tape.
Old July 13th, 2009, 02:23 AM   #34
Shaun's considered reply is correct but I have a small quibble about 'a centre crop of a 4:3 sensor is performed, lowering resolution.'
In fact the resolution isn't affected at all - a road sign is just as readable in the middle of a 4:3 frame as it is in a masked down 4:3 frame. On a 4:3 TV this is very clearly so - but if you then expand this cropped image vertically to fill a 16:9 TV it does appear to have less resolution. But the resolution is actually unchanged; sit further away and the sign is just as legible.
Pete's argument (anamorphic uses all of the vertical resolution) is not borne out in practice and the DVX100B clearly proves this. It's a 4:3 chipped camcorder that has the option of masking to produce 16:9 (whereupon the v'finder image is undistorted) or squeezing the image (then the v'finders show vertical expansion)
Both give the same end result on DVD - in resolution and aspect ratio.
tom.
Old July 13th, 2009, 08:33 AM   #35
Again, my bad for not being clearer: resolution of a 4:3 sensor cropped to 16:9 is reduced COMPARED TO a 16:9 native sensor in SD when viewing on a 16:9 display (NOT letterboxed in a 4:3 display).
Old July 14th, 2009, 03:06 PM   #36
Another benefit to shooting in HD and converting to SD after editing is the ability to crop footage (zoom) to optimize framing and composition without losing SD definition. You can safely go in 20% without perceptible SD softening.
Jim Snow is offline   Reply With Quote
Old February 15th, 2013, 06:49 PM   #37
Re: SD vs down converted HD
I agree with Jim Snow about downloading HDV in HD, editing in HD, and converting as the last step.
What is still confusing to me is what method (workflow) of converting from HDV to SD is the best method before burning an SD DVD. I've tried exporting to Quicktime, then to Compressor/DVD Studio Pro. Have also used MPEG Streamclip and Toast.
The reason this is especially critical at this point in time is that I was hired to video tape series of fast paced soccer games. Just want to reduce the blur and get the best clarity to SD DVD.
Many thanks, everyone.
Leon
Leon Johnson is offline   Reply With Quote
Old February 15th, 2013, 07:04 PM   #38
Hi Leon, you might want to check whichever editing forum we have that best suits your workflow (Vegas / Adobe / Final Cut etc.) because I think you'll find much more info there rather than this camera-specific board. Hope this helps,
Chris Hurd is offline   Reply
