Can Z1 record from PC using firewire cable?
Can the Z1 record from my PC using the firewire cable? The manual (page 98) suggests that you CAN under the heading "To import pictures from the computer to your camcorder."
No luck for me though. Here's what I want to do...I have Flight Simulator running on the PC and I would like to capture the screen real-time movement. The PC isn't fast enough to use a software capture program without dropping tons of frames. I need to capture at HDV resolution. Using the Z1 would be ideal. If anyone has any ideas, I'd love to hear them. By the way, I do have two pc's side by side if there was a way to feed one pc output to the other which could record it. |
I know you can playback video from an edit system (e.g. Premier Pro, Vegas, etc.) into the Z1, but I don't know how you would do what you want to do from a non-editing program.
Nope, firewire doesn't work like that with camcorders. It is used to exchange data with your editing software, not to capture screen activity.
If you have an LCD monitor you could just try filming the screen and see how that looks... |
Hi Chris......
If your graphics card has a secondary Component O/P and your Z1 has Component I/P you may be able to clone what appears on your main screen onto the Z1 that way.
I can do it with my Matrox Parhelia and Matrox PowerDesk software, not up with other makes of cards. If your current card won't do it, a cheap second card with Component out can be configured to clone the primary screen via Windows. CS |
#5 |
A faster CPU is the most practical solution. You can get a quad core CPU, motherboard and memory for dang near $200 nowadays.
#6 |
Thanks guys for your input, been away and just got back.
I'll check out the component idea but I'm pretty sure the Z1 has component out but not 'IN'. I haven't got the camera to hand right now but will check it out an post back. |
#7 | |
#8 | |
The only way to get high definition footage into the Z1 is to shoot it with the lens or capture it from your editing software via firewire. |
#9 |
Thanks Boyd, yes, I meant composite, not component.
Well, here's the bottom line. I've had to order the Hauppauge HD PVR High-Definition Video Recorder for £159 which will do what I want. Hopefully, it will arrive tomorrow and solve the problem. Anyway, thanks for all your input, most appreciated. |
