Z1U Shoe Mount Adapter at DVinfo.net
Old May 5th, 2009, 10:37 AM   #1
Has anyone found a sturdy adaptor that changes the Z1U male shoe design to the standard female shoe mount?
I've got an extension/adaptor that came with my PAG light, but it protrudes too far forward, and is not very stiff. When I get a good sized light on it, the adapter flexs and bounces way too much. (to the point where I worry about it breaking off)
Anyone found a cube or 1-1 sized adapter that just slips over the Z1 shoe and stays rock solid?
Bill Ward is offline   Reply With Quote
Old May 5th, 2009, 01:53 PM   #2
Well for starters, here's a sturdier version of the Z1/FX1 shoe mount: DM-Accessories - FX1-FLAT - a replacement shoe mount for FX1 & Z1
It's made of powder coated aluminum, not plastic like the Sony mount.
You also may be able to mount their coated cube shoe mount made for AIS Sony cameras.
DM-Accessories - AIS-FLAT - Universal shoe mount for Sony camcorders with AIS mount
But the first shoe mount posted should work much better than the original Sony mount.
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply With Quote
Old May 5th, 2009, 11:39 PM   #3
Michael:
Thanks! I had originally looked at that adapter and passed on, since it is similar in form to the inadequate one I already have, but in taking another look, it seems like it could be much more robust. I'll give it a try!
B
Old July 27th, 2009, 06:19 PM   #4
Quick follow-up:
I purchased the DM-accessories shoe adapter, and it's just what I needed. It's very strong, with no flex. It was a tight fit getting it onto the funky Sony-only shoe mold on the Z1, so I'm pretty much going to just leave it attached permanently.
When I took the PAG-supplied "springy" adapter off the Z1, I found the PAG shoe had broken and come apart internally. The only thing holding the unit together was the pressure of the screw thread.
Old July 9th, 2010, 08:29 AM   #5
has someone found a good alternative in Europe?
I bought this one on-line but it doesn't work
it screws in but at the end stay perpendicular so it's completely useless.
Flash Shoe Adaptor For Sony HDR-FX1, HDR-FX1E, HVR-Z1U on eBay (end time 04-Aug-10 19:33:19 BST)
Federico Perale is offline   Reply With Quote
Old July 11th, 2010, 09:07 AM   #6
Federico, check this out Accessories/Spares » Rycote Excellent accessory. I mount a Rotolight, and G2 receiver on mine. Wouldnt leave home without it
Colin
Colin Rowe is offline   Reply
