Time code stuck. at DVinfo.net
Old December 9th, 2008, 07:01 AM   #1
Time code stuck.
Howdy!
It seems to be that my time code format is stuck in UB there are no colons on the time code displayed and it stays as all zeros.
here are my settings
TC preset 00:00:00:00
UB preset 00 00 00 00
TC format NDF
TC run rec run
TC make preset
UB time rec OFF
This cameras time code has been working 'normally' and has suddenly changed. I have all so tried the good old turning the camera on and off and letting it sit a while with out the battery in.
any other suggestions??
Jen
Jennie Stenhouse is offline   Reply With Quote
Old December 9th, 2008, 07:56 AM   #2
Images: 10
You've pressed the button marked TC/U-BIT under the LCD.
Press it again, all will be well!!
If not have you tried playing back an old tape to see if the TC is OK?
Old December 9th, 2008, 08:53 AM   #3
I also guess it's the TC/U-BIT button. But BTW: I guess it's in gerneral no good idea to have TC generation set to preset. That produces TC holes. Regenerate is the thing.
Peter
Peter Rixner is offline   Reply With Quote
Old December 9th, 2008, 09:19 AM   #4
Thanks! that was the problem!
and I set it to regen I totally don't want TC holes!!
Cheers!
jen
