Downconversion between Z1 _FX1 HDV/DV at DVinfo.net
Old November 20th, 2008, 05:07 AM   #1
Hi guys, just wanted to make sure on how to convert An hdv tape trough firewire into dv between a Z1 and an fx1 or a Sony deck!
Could u post the setting please...
i don't wanne make mistakes on the settings!
thx a lot
Stefano Sernagiotto is offline   Reply With Quote
Old November 20th, 2008, 06:36 AM   #2
Ciao, Stefano,
It's very simple. You just turn downconvert on in the camera, and chose the setting you want. "Squeeze" will preserve the 16:9 anamorphic video, which is usually the best, unless you need 4:3 letterboxed for some reason.
Then capture and edit as DV just like you usually would.
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply
