Z1E query at DVinfo.net
Old November 18th, 2008, 08:18 AM   #1
Z1E query
Hi. Someone has advised that you cannot use the mic socket when recording in High-Def. Can you confirm if this is the case? It doesn't sound right. Thanks
James Curran is offline   Reply With Quote
Old November 18th, 2008, 08:25 AM   #2
You can use either the built in internal mic, or an external XLR mic in all shooting formats. You just can't use both at the same time (for example, you can't use the internal on channel 1, and XLR on channel 2 at the same time).
Basically, your info is false.
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old November 18th, 2008, 10:52 AM   #3
Images: 10
Ditto everything Vito has said.
What else did they advise you? I'd love to be a fly on the wall there. HeeHee.
Duncan Craig is offline   Reply
