Drum life question at DVinfo.net
Old August 7th, 2008, 06:02 AM   #1
Drum life question
I'm considering to purchase a used Z1 and the running hours are as below. Anyone knows the typical drum life? Is this considered high usuage? I was thinking of doing some maintenance should I buy it but I'm not sure what are the recommended operating hours between servicing.
Operation: 290 Hrs
Drum Run: 170 Hrs
Tape Run: 130 Hrs
Threading: 340 Hrs
Old August 7th, 2008, 06:32 PM   #2
I thought I read somewhere that the recommended service interval for drums is 500 hours, while the recommended replacement life was 1500 hours.
Note that threading is operations, not hours. So 340 threading operations.
Old August 7th, 2008, 09:09 PM   #3
Thks. So it seems like it is more than half through its service life.
Old August 8th, 2008, 05:22 AM   #4
No, drum run is 170 hours, that's only 34% of 500.
Ervin Farkas
www.AtlantaLegalVideo.com
Old August 8th, 2008, 12:07 PM   #5
You could look at it even more charitably by using the tape run number into the lifespan, which is 1500 hours or so, so only about 12% of its total life on that basis. I think the 500 hours figure is for service, not replacement.
Old August 19th, 2008, 08:06 AM   #6
This is a question I've often asked myself as well. I can't find any official figures from Sony. Does anyone actually know the maintenance schedule/recommendations for cleaning or servicing the camera, and for drum life?
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply With Quote
Old August 19th, 2008, 12:10 PM   #7
Here is a official technical bulletin from Sony for the complete DSR-3xx and DSR-5xx DVCAM camcorder series. It's a user manual correction that says the video heads need to be replaced after 2000 hours instead of 1500 hours. I guess this also will apply for other DV, DVCAM, HDV equipment.
http://supportdocs.sonybiz.net/index...6/00041984.pdf
It's good to service the heads after 500 hours. I always did.
Hope this helps!
Ivan Snoeckx is offline   Reply With Quote
Old August 19th, 2008, 12:11 PM   #8
If I recall correctly, the numbers I cited above were from a Sony Maintenance manual for one of their DV tape decks, I think the DSR-11.
Old August 19th, 2008, 12:21 PM   #9
Operation: 290 Hrs
Drum Run: 170 Hrs
Tape Run: 130 Hrs
Threading: 340 Hrs
These are very low hours. The camera has still a whole life to go when you handle it with care.
Old August 19th, 2008, 05:54 PM   #10
500 hrs I have know is on those SONY VTR Deck. Cam not sure. But now I know when the NOs hit the target, will need for servicing Thanks
Edit on Adobe Creative Suite Production Premium CS5 Mac 64BIT
K.C. Luke is offline   Reply With Quote
Old August 21st, 2008, 02:59 AM   #11
Operation: 290 Hrs
Drum Run: 170 Hrs
Tape Run: 130 Hrs
Threading: 340 Hrs
Sean you just got a new EX1 and looking for a Z1 so soon? Is this your B cam or you do not like your EX1?
John Woo is offline   Reply With Quote
Old August 22nd, 2008, 01:02 AM   #12
These stats are only availabe from the Z1 -
Is it possible for a say, a sony engineer to discover these stats on an FX1 or are they just unavailable??
Chris Coulson is offline   Reply With Quote
Old August 26th, 2008, 06:23 PM   #13
Does this sound ok or has this camera been abused
FOR SALE
Sony Z1 HDV handycam $3,000. ono (GST inc) Includes battery (NPF570) and AC adaptor/charger (AC-V700).
Operation 450H, Drum Run 320H, Tape Run 160H, Threading 480.
Only used for filming. Digitised footage using dedicated player.
In good condition. All offers considered
what are your thoughts on this one
Rob
Robert Bec is offline   Reply With Quote
Old August 31st, 2008, 08:18 PM   #14
I would think you could get it for less than $3000. For that many hours on it at 320 drum run. A new Z1 goes for about $4000 from B&H. Always talk to the people in voice and get a feel from them about the cam use and go with your vibes/gut feeling. But $3000 sounds to much to me. I'd pay maybe $2500 or less.
Ben Hogan is offline   Reply
