HDV Vs DV when mastering to DVCAM - Page 2 at DVinfo.net
Old July 15th, 2008, 05:32 AM   #16
Originally Posted by Ali Jafri View Post
I've had huge problems trying to downconvert 1920x1080p HD footage to standard definition 4:3 using software alone.
Ali, some NLEs had issues downconverting when HD first came along, but by now most of them have fixed all the problems. Please specify what soft you used.
Ervin Farkas
www.AtlantaLegalVideo.com
Old July 15th, 2008, 11:18 AM   #17
martin, please also specify whether the downconvert is software based or hardware. I've had huge problems trying to downconvert 1920x1080p HD footage to standard definition 4:3 using software alone. I believe there are some hardware cards that do a better (and quicker) job. Please do comment.
Ali,
My experience has been with software solutions only, downrezing either in Final Cut or in Shake. I haven't given it much thought, but I'd expect that downconvert algorithms are relatively simple (especially compared with upconverting to higher resolutions). Whether the algorithms are implemented in hardware or software should, in theory at least, only affect the speed at which they can execute.
Sorry, I probably don't have the information you were really looking for...
- Martin
Martin Pauly
Martin Pauly is offline   Reply
