My work flow to SD from 50i HDV and sample
Hi there
I have been reading a fair bit about down converting from HDV to standard DV without losing too much quality and, as I own a HDR-FX1E and DONT own a High definition TV, I am very interested in having a work flow that maintains as much quality as possible after rendering to SDV MPG2 and DVD output. I like to deinterlace and use my FX1 for several genres. I use Sony Vegas7 and swear by it! Here is what I have come up that I like the look of very much! 1. shoot in 16:9 HDV interlaced with sharp set to 12. Im NOT using either cinematone or CineFrame (tried it and opted not to use). 2. I capture to HDV to PC using CAPDvhs (really seems to preserve qiuality) 3. I have purchased DV Film maker and use the 'deinterlace' option and render using canopusHQ codec. 4. Use files in vegas/ color correct etc and then render out using Architect DV widescreen template with field order set to progressive. 4. Medium framed shots I use a light unsharp mask but close ups I leave as is. This appears to really hang onto a great looking file to my eyes. I have converted a short sample to wmv and can be downloaded here: http://www.savefile.com/files/1438738 I had files rendered to mpeg2, put back into vegas and rendered out as the wmv file. Have a look (its about 19mb) and see what you think! cheers Jamie Last edited by Jamie Roberts; March 14th, 2008 at 02:01 AM. |
Hi Jamie,
I cant seem to access yor file? Whats "I capture to HDV to PC using CAPDvhs" I use vegas 7 & also 8.... i think the capture in Vegas is great and have never had a problem with quality loss I have had a few problems getting a good work flow and now seen to be getting here slowly. I like Veags and was about to switch to a Mac but having spent so much time with Vegas i will stick it out for a while. Cheers Simon |
Hi Simon
Sorry this is the link http://www.savefile.com/files/1438738 What I meant was when I capture the video onto my PC computer, I keep the video as HDV and use a free software program called CapDVHS. I have had my FX1 for a while and have really noticed the quality loss when both downconverting in camera, attempting to down convert using various software methods etc. I had read a bit about DVFilm maker and finally wen ahead and bought it after having a look at the demo. This a fairly cheap (about $145) and really helps with conversion. I am using the canopus codec but think you could easily use the free 'huffy' codec which creates fairly large files but is lossless. Vegas is very professional piece of software but a dream to learn and use! cheers Jamie |
The best work flow for downconvert for me i have found is.
Record HD, capture HD in Vegas, edit CC etc... in Vegas and then render to mpeg-2 in Vegas using 2 pass VBR This after many hours of testing has given me the best looking SD DVD that i can achieve. Rules that i use. Record HD to get SD. Make sure of plenty of light. Watch for focus. Cheers Simon |
