#31 |
Marcelo - I mount my 20-DW2 video light horizontally off a cold shoe I've attached to the vertical bracket I've got on my Z1 - shown here:
http://www.camcorderuser.net/cpg/dis...at=10075&pos=2 I'll try and find time to put up a picture of the light in place. tom/ |
#32 | |
Regards |
#33 |
Marcelo, what exactly is you are trying to accomplish? I have shot wedding receptions where the ONLY light was candles on the tables and it looks fantastic with 9-12 dB gain even in HD (perfect down-converted to SD).
It doesn't look like you're a beginner, but I will still mention this - please don't feel offended: are you trying to make that footage look like it was shot in a normally lit place? To call the Z1/FX1 "terrible" in low light is simply unimaginable to me... in the price category they have by far the best low light capability! |
#34 | |
I think that I wrote it badly, my problem is not really under low light condition, it under disco environment, in a disco floor, where the lights change a lot and very fast... So I'm getting a lot of square blocking as you can see on the pictures, the 1st one is ok, but the next frame, when the light changed brutally, I got this bad looking, check it: http://www.mnproducoes.com/square/1st_frame_ok.jpg http://www.mnproducoes.com/square/ne..._toosquare.jpg This problem I did not have when I was shooting with DV using my PD and VX (I believe if I shoot in DV mode using Z1, I won't get these squares)... So another pros on this thread explained that it is a HDV problem, because it uses MPEG compression, so, I need to live with it, use some soft light to minimize the problem, do not push gain too much (+9db at maximum), record with shuttle like 60 maybe 30... Thanks a lot for your attention, best regards Marcelo |
#35 |
Thanks Tom. Here in Brazil we have a Disney's character that we call Professor Pardal, he is a bird that has a little robot lamp as his helper, he creates a lot of cool stuffs... Your are Professor Pardal...
We have something in common... I'm a huge fan of VX2000 too... I saw a lot of interesting things, but one called my attention... The 20-DW2 with 2 balls joints that gives flexibility to the light... Do you have something like it that I can attach to Z1's shoe? This way I could have a a flexible light on the top of my Z1... If yes, where can I buy it? Could you please send me the link? Thanks, best regards. Marcelo |
#36 |
Professor Pardal in auto-reply mode ...
Yes, to make your 20-DW2 lamp more 'aimable' why not fit it to one of those little hot-shoe extenders that SLR owners fit between their top mounted electronic flash guns and the camera? These you can lock in all sorts of positions to aim the light up, down or even (if you fit it in the Sony shoe at 90 degrees) sideways. The other way is to buy a dedicated LED lamp that has pivot points in the arms that attach the little lamp housing to the battery base. I'm testing one right now. Go to http://tnpbroadcast.co.uk/equipment.php?row=9&new=1 and look for the PRO-X XD-L32S for a look-see. PP |
#37 | |
I found 2 hot shoes as you said at BH, do you think that it is going to fit on the cam and on the light? Please, if possible check the links: http://www.bhphotovideo.com/c/produc...e_Mount_1.html http://www.bhphotovideo.com/c/produc...lash_Shoe.html thanks a lot Regards Marcelo |
#38 |
Exactly right Marcelo, and I have both those shoe adapters and both work OK. You don't need the hot one - the cold one will do. Only downer is they're not 'lock-down' shoes and simply rely on friction between foot and shoe. Look for a locking one.
And don't worry - your 20-DW2 lamps are excellent at the price - much better than the LED I'm testing. |
#39 | |
I just do not understand what you mean by cold and hot... In your opinion, which one is the best? Hama or Kaiser (both have the same price) ? I tried to look for a shoe with locking, but I did not find it at BH... My brother is in USA, so he will bring it to me on March... Thanks again Marcelo |
#40 |
A hot shoe has electrical contacts, a cold one does not.
