Z1U backfocus out? anyone else with the problem at DVinfo.net
Old January 25th, 2008, 10:31 PM   #1
OK,
I'm just curious. Am I the only Z1u owner who's focus sucks on that camera? I'm used to broadcast lenses and the DVX/HVXs where you can push all the way in, pull your focus, the pull out and you are fine anywhere within your zoom range once you have that critical focus.
However, with my Z1u, that is not the case, If i zoom all the way in, focus, and pull out, I am not sharp.
whatsupwiththat? Is that all Z1Us or just mine?
-C
Colin McAuliffe is offline   Reply With Quote
Old January 26th, 2008, 01:01 AM   #2
We have 4 - Z1U's at work and they all do the same thing...I do not use the "backfocus" anylonger with the Z1U it comes up too soft and never works like it should. I wonder if this has something to do with the chip size if not then why does it do that...
Zach Stewart is offline   Reply With Quote
Old January 26th, 2008, 09:12 AM   #3
I've never had a single problem with backfocus on my Z1, it works like any camera should in that regard... But if it's giving you serious trouble, try the focus assist? 101 ways to do the job. :)
Carl
Carl Middleton
Whizkid Mediaworks
Carl Middleton is offline   Reply With Quote
Old January 26th, 2008, 12:33 PM   #4
ok, i think I probably shouldn't have used the term 'backfocus'.
My real question is weather or not all Z1Us will not keep the same focus point throughout the full range of the zoom. Ie. if i focus when i'm pushed in, I'm not in focus when i pull out.
The reason i ask this is because i'm trying to figure out if i need to send my rig in for repair or not.
Old January 26th, 2008, 03:09 PM   #5
I can't say for sure, but it sounds like you might.
In hundreds of hours of tape run on my camera doing nature/adventure/etc video plus a good bit of corporate and cinematic, I have never once had a problem with the good old zoom in, focus, zoom out method of focusing....
Carl Middleton
Whizkid Mediaworks
Old January 26th, 2008, 03:19 PM   #6
Just did a test with my Z1 using a back focus chart and peaking to check the focus point. The focus held perfectly from full telphototo to wide angle right in the centre of the chart - the peaking indicator stayed right in the middle for the whole pull back.
My conclusion is that my Z1 does hold focus perfectly - so it is likley that yours is not adjusted correctly
Graeme
Graeme Fullick is offline   Reply With Quote
Old January 27th, 2008, 02:31 AM   #7
There is mention in the EX-1 forum of backfocus adjustments via a service menu on the Sony EX-1. I wonder if there is not an equivalent sevice menu and/or adjustment with the Z-1/FX-1?
Eric Lagerlof is offline   Reply With Quote
Old January 28th, 2008, 11:39 AM   #8
its funny,
i just checked the cam with a backfocus chart and it seems fine. the chart blooms throughout the whole zoom range. I'm thinking it might just be that I'm zooming in and focusing on people that are standing too close to the lens maybe? perhaps when you are within 2 meters it does a macro focus? I dunno, i guess ill have to check it some more with bigger targets, like humans.
Old January 28th, 2008, 11:51 AM   #9
Oh, THAT!
I've had that happen, when zooming to 99 on a static object at about 3 feet. I said screw it and made an artsy montage using the effect. Worked well.
But yes, I have seen that. It'll hold the focus on the object, allowing you to zoom out (and it loses focus) and back in (and it snaps back in focus) correct?
I'm assuming that is a macro focus or something crazy, but yes, at full zoom on a close object, I have seen an effect similar to your description. I assumed you were talking about zooming into a face to set your focus, etc. Sorry.
C
Carl Middleton
Whizkid Mediaworks
Old January 28th, 2008, 11:54 AM   #10
alright,
I think i actually figured it out. I guess since i do so much low-light work with this camera (mostly press events at dark venues with a litepanel on the cam) I was always shooting with an open iris (1.6). then, when i push all the way in and focus, the iris is close down to a 2.8.
does that make sense? it seems that when i test with a chart at 4.0 I have no focus issues whatsoever.
I think that the iris and macro issues together, are what were causing the problems
Old January 28th, 2008, 04:58 PM   #11
Possibly.
My first Z1 seemed soft, and I'm pretty sure now that it may have had a back focus issue. I didn't trust it and was forever fiddling with focus and feeling sick about it.
Luckily (?) it was stolen. The new Z1 can be zoomed in, focussed, zoomed out and it's still sharp - rinse and repeat - the lens holds focus.
I guess there are some Friday Afternoon Z1s out there, simply because of the volume in which they're made.
Matt Davis is offline   Reply
