Z1U with a disk???
Is there a Hard Drive Disk where, instead of recording to tape, you may record straight to the Disk for faster editing.
I am trying to get DVD's made for my School's Football Coaches and they are getting tired of staying with me 'til 1AM to get their DVD's done. (and under- standably so!) Joseph P.S. I heard you can with the A1U, but I have a couple of Z1U's. Check out my work, and tell me what you think at... nearsightedproductions.com |
Yes,
I have the V1U and I use the Sony HR60 hard drive recorder with it. Its VERY small and can be attached to the shoe on the camera. It was expensive but I love mine! I also have a few of the nNovia drives too. They work just as well as the Sony drive but are a lot larger. The transfer rate into the computer is faster with the nNovia too. The price for the nNovia can be a bit less than for the Sony drive. Either way once you go tapeless you won't want to go back. Chris
http://www.LandYachtMedia.com |
I want to second the Sony HR60 choice. I use it to film sports for a small cable tv station. The advantage of HR60 is that it has this sort of auto detect mode, where you can switch from recording HDV or avi and not have to change a setting on the hard disk.
Since I saw from your website that you are Apple based... The nNovia drives have the option for you to record Quicktime files. I've never used one but I think the Firestore products have a similiar option.
http://twitter.com/tedmcneil |
But will the HR60 work with the Z1U???
Joseph nearsightedproductions.com |
#5 | |
The HR60 even works well with my HC3!! :) Chris
#6 |
Thanks, But Where Did You Buy???
Where did you all but the HR60, and how much was it.
Thanks for the GREAT news!!! |
#7 | |
You can check the recorder out at this link: http://www.bhphotovideo.com/c/produc...Recording.html It comes with everything you need out of the box except a battery. Luckily it uses the same battery as the V1/Z1 so if you have spares you will be set.
#8 |
One other thing...is the HVR-DR60 compatible with Final Cut Studio?
nearsightedproductions.com Last edited by Joseph Hutson; September 16th, 2007 at 06:04 PM. |
#10 |
I chose Focus Enhancements
I have decided to buy the FS-4 HD Pro. The reason is, it writes more varieties of files, and it is cheaper, upgradeable, and most of all, I won't have to worry about having to convert .mp2 files to .mov files.
Thanks for your input, and I thank you for your time! Check my new website out at... nearsightedproductions.com ...and let me know what you think. |
#11 |
Buy scopebox - and record it in any format right onto the hard drive of your computer.
-j |
#12 |
The Sony also is formatted in FAT32? It seems that most of the direct-to-disk options use FAT32 instead of NTFS, despite the filesize limit.
I guess there is a reason. I would be interested to know it. |
#13 |
Its done for several reasons. I feel these are the major ones.
Compatibility with MAC. MACs can read but not write to NTFS. Second is that NTFS is owned by Microsoft and you must pay a royalty to use it. Chris
#14 |
You must pay what and why to MS? You are just formatting.
#15 | |
You must purchase a license from MS to gain access to the specification that allows you to write your drivers so they can interact with a NTFS partition. Also if you are going to establish a partition you have to know how to do it and have copies of the base software that is contained in the master boot record. Chris
