Tim's Beach - Z1 Footage at DVinfo.net
Old September 6th, 2007, 12:51 PM   #1
So, I was testing my new Sony Z1 yesterday evening at the beach, shot some random stuff got home and edited...it's sorta medium quality as high was like 192mb.
http://img131.imageshack.us/img131/2412/timct7.jpg
Filmed in DV.
Any way this is what came out:
http://www.sendspace.com/file/gucgr0
http://www.waroftheservers.com/TimsB...rtStoneman.wmv <-- right click, save as.
Oh yeah and i did this too:
http://img209.imageshack.us/img209/1...ogoncamyh2.jpg
VIDEO:
http://www.sendspace.com/file/guraay
Hope you enjoy, any tips on rendering footage be most welcome!
Robert Stoneman is offline   Reply With Quote
Old September 6th, 2007, 01:01 PM   #2
Robert:
You can shoot HDV on any DV tape.
Chris J. Barcellos
Old September 6th, 2007, 01:11 PM   #3
Oh? - i was told different then... arg. Thanks for the heads up.
Old September 6th, 2007, 01:29 PM   #4
Some argue that using the HDV rated tape protects against drop outs more. Others argue its the same tape with a different label.
Proponets say Drop outs in HDV can cause a 15 frame loss, as opposed to DV which can affect just a few frames, so use of premium quality tape is best.
However, the physical recording space on the tape is exactly the same. I've been using a TDK $3 brand on my FX1 for two years, with no issue.
Chris J. Barcellos
Old September 6th, 2007, 01:45 PM   #5
Thanks very much for that Chris, very informative!
Old September 6th, 2007, 02:04 PM   #6
Those that argue it's the same tape with a different label are idiots.
There are different grades of tape. Always have been so.
HDV-rated tape has a higher carrier signal which assists with preventing dropouts/error correction. This may or may not be important to you, but there is indeed a difference in various tape grades, where they are cut from the reel, and the emulsion/adhesives used in the tape. Additionally, the shells are usually a higher grade shell, simply for purposes of keeping contamination to a minimum.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old September 6th, 2007, 02:19 PM   #7
My point was he didn't have to forgo shooting HDV because he didn't have a tape labeled HDV.
Chris J. Barcellos
Old September 6th, 2007, 02:40 PM   #8
I use the HDV tapes when a dropout would be intolerable. I also use them when a dropout would cause me headaches in post.
From my experience, ordinary miniDV tapes perform pretty well recording HDV material as long as I don't try to use one ore than once. There is a really good chance that recording an entire miniDV tape in HDV will result in no dropouts. However, it happens usually maybe once per tape.
Wesley Cardone
www.WCardoneProductions.com, Detroit and Lansing, Michigan
Wesley Cardone is offline   Reply With Quote
Old September 6th, 2007, 08:23 PM   #9
You may need tripod.
Peter Robert is offline   Reply With Quote
Old September 7th, 2007, 02:56 AM   #10
I only got the camera yesterday so bear with me there ;)
