Latest commercial!!! at DVinfo.net
Old August 15th, 2007, 09:26 PM   #1
Here is a commercial I made today and yesterday. Youtube doesn't do justice for a high def camera like the Z1U. I don't have my own website with aserver so I have to show it on youtube. bummer
http://www.youtube.com/watch?v=hrLwsiFzDBM
All criticism welcomed.
I am only 16...so...
Joseph
Joseph Hutson is offline   Reply With Quote
Old August 16th, 2007, 01:04 AM   #2
Joseph,
not at all a bad piece of work!
Mixing aspect ratios is generally frowned upon, I noticed at least 3 different aspect ratios in there.
Since it's a commercial, some additional "teaser" text might be useful to help lead into the final "Back to School" title card.
Thanks for sharing your work.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old August 16th, 2007, 07:00 AM   #3
It works. I agree with the above comments. Here some other things to think about. The problem with editing programs, is that it is too easy to put in a bunch of different effects and wipes. A good rule is to "not use an effect for the effect's sake". This means to make sure any wipe or effect you use has a purpose that enhances or supports the message. Watch most commercials, and you will see that the dissolve or a dissolve variant is the most commonly use transition in television. I liked your humor, it was funny, which is good. Keep up the good work.
David Stoneburner is offline   Reply With Quote
Old August 16th, 2007, 10:23 AM   #4
Not happy either
I wasn't happy with the different pixel ratio...I knew I wasn't going to be the only one who noticed. hahaa
Thanks David and Douglas!!!
Joseph
Old August 16th, 2007, 11:14 AM   #5
By the way, what did you mean Douglas with "Since it's a commercial, some additional "teaser" text might be useful to help lead into the final "Back to School" title card." I didn't understand what you meant.
Joseph
