#16 |
Hi Ralph,
I had a similar problem when I first got my Z1. To correct the issue, I had to go into the menu and under AUDIO SET > XLR SET > INPUT1 TRIM, I changed the setting to +12dB. I then did the same for INPUT2 TRIM. I don't know if the V1 is set up the same way (or if you've already tried this) but if it is, this may solve your problem. Regards, Mark |
#17 |
Yeah...I guess this is where Sony went wrong with the V1 design. Here is an excerpt from the manual:
"The INPUT TRIM function adjusts the input level from an external microphone. When using a highly sensitive microphone, set it to minus side. When using a less sensitive microphone or recording quiet sound, set it to the plus side" Only... there is no plus side in the V1 menu!
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#18 | |
--Ralph
--Ralph Roberts, CEO 1VIDeo / aBOOKS / Creativity, Inc. |
#19 | |
--Ralph
#20 | |
