Figured I'd show off some FX7 specific work...
This is running at very low aperature, high shutter (1/2000) and 60i converted to 30p in post.
I film paintball, been playing for 6 years and filming for 4... this was the first time I filmed with the FX7 for anything so I was still getting very used to it but this is what I came up with.. http://www.lousyheros.com/videos/xpslslo.wmv - This is the "smooth" slow motion feature, I didn't realize it recorded at 1/4 the HD resolution, so it's 460 x 280 instead of 1920 x 1080... sucks but that's what you end up with... I had a lot of those shots and just threw them together with some music... no editing of any sort http://www.lousyheros.com/videos/xpslpat.wmv - This is the HD stuff at 1280 x 720 in 30p... compressed twice by accident and it came out funny in the .wmv so don't take this as a measure of the quality of the camera, it's all .wmv compression. If anyone wants some full HD clips I can give short raw .m2t files in 1080p30 |
So much for the idea of rolling shutter problems! That was fast action at a high shutter speed and high framerate. I don't think you could ask more of an HDV camera. Even though the footage is low resolution, it has that great FX7/V1 color. To see the ammunition streaming from the gun in the slomo shots and to find out that it isn't even visible in the normal rate footage really speaks well for the FX7 capabilities. Good job and thanks for the demo.
Yeah, I've always been saying the rolling shutter effect is a greatly exagerrated thing, at least with the V1 (and I suppose FX7). In progressive mode, when I need DOF as shallow as only possible, I shoot at 1/300th on a regular basis. I tried 1/600th - no rolling shutter effect, either - not that could be seen by somebody not looking for it!
BTW, with 1/600th I can keep the iris at F1.6 -2.8 without this annoying ND-filter switching on and off each time some cloud would cover/uncover the sun, or moving from bright sunshine to some shadowy scenery. Stroby? -perhaps, but I like it that way! Progressive, razor sharp. And with a controllable DOF, too!
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive Last edited by Piotr Wozniacki; July 9th, 2007 at 07:22 AM. |
I shot with an HV10 at the same shutter speed, at very fast pans (similar to these) I noticed rolling shutter slightly... I think it may have to do with single cmos over 3 cmos...
But I did notice more noise with the FX7 in certain shots at high shutter, I'm probably going to go back to 1/1000 |
#5 |
Make sure you don't have the gain on automatic. Extremely high shutter can cause a lack of exposure so the camera would increase the gain. Are you using any filters that cut down the light? When shooting at very fast shutter you probably need to remember to turn off the ND filters. If you are using a polarizer, you will need to weigh it's benefits against how much light it soaks up.
#6 |
Just UV... I don't think I had any ND filters on, I might have... gain wasn't locked...
I didn't figure out how to lock the shutter speed until a couple tapes into filming... still figuring out the camera :) |
#7 |
I calculate 1/2000 as about 5 f-stops less light than 1/60 shutter. In a bright outdoor scenario there should be enough exposure to not need gain at that shutter as long as the ND filters are not engaged. I could be missing something, but double check things when you are doing extreme shutter speeds. Regardless, I didn't notice noise and the shots look great.
#8 |
Nah no noise in those shots, but certain shots all the black clothing on players and masks is grainy and bugged the crap out of me... I never experienced any noise when I was filming outdoors with the HV10...
#9 |
"gain wasn't locked..."
Video noise is only caused by gain. Something probably caused the auto-gain to kick in and you got noise. ALWAYS keep your gain on manual. Shutter or iris can be on auto and won't ruin your image. Gain on auto will randomly ruin your image quality. If you want to have fully automatic exposure, go in to the menu and limit the auto gain to 12db. 12db is noisy, but not so bad it will ruin things completely. 9db is probably just below the threshold most people will notice. 6db is barely visible. Does the FX7 have Black Compensation? |
#10 |
I have auto gain limited to 6dB, to always be on the safe side when in Exposure 1 auto mode. Only if I do need some more desperately I crank it up manually (after going to manual exposure of course).
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
