argh! Image moving vertically- at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old June 20th, 2007, 07:00 PM   #1
Doing a shoot today with the V1U when the image started moving up and down. At first I thought I'd bumped the tripod, that's kind of what it looked like, but it wasn't the tripod. The picture was actually rolling up a bit and then back down. When zoomed way in it was really pronounced. Wide shots were generally OK. Any ideas?
Mark OConnell is offline   Reply With Quote
Old June 20th, 2007, 07:40 PM   #2
The manual of most cameras with image stabilization recommends to turn off the stabilizer when shooting from a tripod. This is likely the cause of your problem. The stabilizer is getting fooled and compensating for movement that isn't real.
Old June 20th, 2007, 07:42 PM   #3
I don't know Marcus, I've been shooting with this camera for several months and it's never happened before.
Old June 20th, 2007, 08:14 PM   #4
OK. I just went and messed with it a bit and the movement does look a lot like that from the stabilizer. But if that's it what would cause it to freak out that way? Also, before I start rejoicing in the idea that the problem isn't with the camera but rather with the monkey, are there any other possible causes?
thanks-
Old June 22nd, 2007, 04:58 PM   #5
The vertical motion returned the next day. No idea what could cause it. Camera is currently at the Sony service site in NJ. I'll let you know what they say.
Old June 23rd, 2007, 12:30 AM   #6
Mark,
I reported this "problem" before
http://www.dvinfo.net/conf/showthread.php?t=88427
When Steady shot is OFF, it’s OK
and it never bothered me then, actually shooting
volki
Max Volki is offline   Reply With Quote
Old June 23rd, 2007, 03:10 PM   #7
Max, what you've described fits my experience almost perfectly. Maybe it is just steady shot. I have to wonder though why it never happened before? I've been doing pretty much exactly the same shots for the same program in the same location under the same conditions for the last four months and this hasn't happened until this week. I sent a short clip of the movement to the Sony guys in NJ and they said I should send in the camera. If they end up saying the same thing that the guys in europe did this will have been a big hassle for nothing. Anyway, nothing to do at this point but to wait to hear from them.
Old June 24th, 2007, 02:10 AM   #8
Did you happen to be using any kind of radio device near the camera such as a walkie talkie or other comm device?
Matthew Greene is offline   Reply With Quote
Old June 24th, 2007, 12:50 PM   #9
Wireless mic-
Old June 25th, 2007, 12:40 AM   #10
At that time, in that room, HD-TV (CRT!!) was on, 3 ft away,
Also a Deepfreeze and some computers, 10 ft away
Well, a CRT could have some influence?
But, 2 weeks later, I went on a trip abroad and had the V1 behind the windscreen in a fast moving car, on a car-tripod installed, Steady Shot was ON. I took some trial-shoots, passing landmarks, road signs, and so on.
Surprisingly good pictures, a bit dark, because windscreen is a bit tainted,
Very sharp, no artefacts, even at the side, where road signs, bridges, bushes, flashed by
Even the sometimes very noticeable vibrations where damped so good, that in the pictures, previewed on the “big” TV with HDMI-in, was only very slight vertical movement visible at the very top of the picture
So Sony’s recommendation, Steady shot always OFF, while using a tripod, depend on different circumstances.
volki
