V1U Camera mic just died on me - Page 2 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old May 27th, 2007, 05:58 AM   #16
have to agree with marcus that the stock mic isn't too sensitive.
lesllie
Leslie Wand is offline   Reply With Quote
Old May 27th, 2007, 09:32 AM   #17
It's a trade off, I think you're missing that. If the stock mic is too sensitive, then it picks up everything happening around the camcorder. Do you want it so sensitive that it grabs the record button being pushed, your breathing, the tape mechanism? If you do, then throw an AT 4053 on there. It's a hyper card, and will only pick up close/front, but it will hear all the transient sounds from the camcorder as transmitted through the body as well.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old May 27th, 2007, 11:03 AM   #18
MPS Digital Studios
One small thing I want to add about XLR cables...DON'T wrap them like you would an extension cord (around your elbow and hand), where the wires can get crimped. A friend did that once at a wedding I was shooting about 8 years ago. The $25 XLR cable was shot after that.
Over and under; I've seen XLR, S-Video and even extension cords all get screwed up because of wrapping it wrong.
heath
My Final Cut Pro X blog
Old May 27th, 2007, 04:50 PM   #19
Heath is right. You can look at extension cords and see if they've been wound incorrectly. The internal wires get kinked inside the outer sheath and make it look like it's been braided from the inside. If that sort of thing would happen to a mic cable with it's fine wires, I'm sure that would be the end of that. Another thing I have noticed is that the stock mic's cable protrudes pretty far from the XLR plug when connected and that crimps the cable when I put it in my camera case. I now always unplug the mic when putting the camera away.
Marcus Marchesseault is offline   Reply
