mounting add-ons on the V1 - Page 2 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old May 23rd, 2007, 12:58 PM   #16
Michael, are you using it with the Sony ECM-NV1 mic? If so, that's what I'm looking for! Even if it's another (longer) mic that you're using, please let me know what is the distance between rubbers in this mount; thanks in advance!
No I curerntly use it with my Rode NTG2 mic.
http://www.bhphotovideo.com/c/produc...icrophone.html
or I might use my AT835B mic, which is much longer.
I personally would recommend using another mic rather than the ECM-NV1. As there are much better mics (even inexpensive mics) out there than the ECM-NV1.
The problem with using another shock mount and the ECM-NV1 is that I find you are petty much liited to using it with the supplied shock mount only because of its barrel configuration (made to fit perfectly into the PD170 shock mount).
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply With Quote
Old May 23rd, 2007, 01:59 PM   #17
Yeah, the NT-G1, NT-G2 and similar, longer shotguns fit perfectly in the Azden shock mount I have, as well. Thanks, anyway!
