sky overexposing: will French flag help? - Page 3 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old May 28th, 2007, 02:44 PM   #31
OK - so by "Knee Level" you mean the degree of flattening the curve, and not where the switching point is located on it. You are right - BTW, the "level" as you understand it is not enough on the V1, IMHO - even with its strongest settings, which is "Knee Low"...
Thanks for the clarification. BTW, how does the "auto" setting for Knee work in your opinion? This often helps (on the F-900) if you are panning back and forth from, say, a wall to a bright window. Anyone tried the "auto" setting?
Simon Hunt is offline   Reply
