saturation difference between hd / sd at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old May 11th, 2007, 01:20 AM   #1
still investigating all the options....
i shot a static scene in hd at default settings (ie. no profiles, etc.,). looked great, but lacking in saturation, HOWEVER, i then did both a in camera conversion to sd, and also recorded the same scene in sd. both the sd versions looked more saturated?
am i missing something?
leslie
Leslie Wand is offline   Reply With Quote
Old May 11th, 2007, 05:11 AM   #2
You watched the clip on your computer? There will be conversion differences in levels between an mpeg2 and a dv file especially on playback. Try opening the frames directly with virtualdub etc to really see what they look like.
Mikko Lopponen is offline   Reply With Quote
Old May 11th, 2007, 06:01 PM   #3
hi mikko,
i monitor on both pc and crt. will have a look at virtual dub later today. but i still want to know which i should be monitoring if i want to cc or tweak images.
leslie
