CP: Level of Headphone output
I have 3 pairs of headphones to try, and 3 types of micros, but the sound level what’s coming out of my V1-headphone contact is to low.
I can hear "loud" noise, but checking if there is wind blubber is not possible. Are there any headphones where I can amplify what’s coming out of the V1? Or is it possible to lift the output to headphones in V1-menu? I haven’t found a setting to do this volki |
This has been covered here before. I feel that the output is marginal even with low impedence headphones. Others are feel it is sufficient. Compared to broadcast camcorders I use it's very low. In order to get enough gain with my Sony MDR7506 phones I purchased a battery powered amplifier from Boostaroo
http://www.boostaroo.com/store_detail.php4?id=14 It provides more than enough gain and if you shop around you can get it for less than $25 USD. The downside is that it's another accessory you have to carry around. I use it to tape interviews or presentations, but not for run and gun shooting. |
The Z1 also has a very low headphone output, i've had a number of soundys ask me to turn it up!.. and thats when its been sitting at full volume.
Simplest fix. Buy a pair of cheap cans. The Takstar DJ headphones are about as good as it gets, should be able to buy them off eBay. Never found anything from a retail outlet to match them. Don't use them for anything else of course but for a set of cans plugged into a prosummer camera they sure beat the 7506s etc.
#5 | |
Excuse me, but shurly by "Can" you mean "Headphones", not something like a "can of worms“? Could you also tell me what “7506” means? Volki, Switzerland |
#6 |
Max,
If you buy the wrong headphones you could open up a "can of worms" when you review your footage ;) "Cans" is used as an English colloquialism for headphones. |
#7 |
#8 |
Sorry, I forgot to mention that I use a Beyerdynamics MCE 86N(C) S Mono shotgun mike instead the Sony.
I used this before with my PD-150 and can’t remember having hearing-problems with the same headphones I tried now with the V1 Thanks for your headphones tip volki |
#9 |
The mic you choose will have a huge impact on the output levels (and input levels) of the camcorder. Using an AT 4053 for example, monitoring 7506, there are no issues at all. Sensitivity, coupled with autolevels, etc all play into output/input.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#10 | |
The 7509s only advantage over the 7506s is a bit more bottom end. Problem we've had with the 7509s (and I assume the 7506s would have the same problem) is the curly leads fail where they enter the plug and as it's tinsel wire inside it's no simple task to replace the plug. Definately way better headphones than the el cheapo ones I'm recommending for use with cameras like the PD170 except they're not sensitive enough. Another solution to lack of headphone volume is this little box: http://www.rolls.com/products/pm50sob.php Don't remember who it was that put me onto this thing, might have been Spot. Sure is very usefull, you can feed the line from a boom mic through it and the boom op can adjust the levels in his headphones without affecting the recording levels. Or you can use it as a conventional headphone amp. |
#11 |
Maybe this will explain, why audio is low, with some "cans"
---------------------------------------- Knowledgebase Document: 1026389 19/04/2005 Low audio on HI-FI headphones Description Why, when I use my HIFI headphones, is the audio so low? Solution Headphones impedance can be as low as 8 and as high as 300 ohms. However since the audio output specification states that the impedance is less than 22k ohms, one must expect an impedance mismatch, which will result in lower audio than the output from a HI-FI amplifier. Applies to HVR-Z1E and ALSO TO V1E ------------------------------------------------ volki thank you all for your help |
#12 | |
Shure E2C
Some advantages are their small size for field work, different size soft ear pieces, quality sound, and tough little storage case. Here's the info: Technical Specifications * Speaker Type: Dynamic MicroDriver * Sensitivity (at 1kHz): 105dB SPL/mW * Impedance (at 1kHz): 16 * Cable Length: E2c: 1.57m (62 inches) E2c (in black): 1.45m (56 inches) * Net Weight: 30g (1 oz) * Input Connector: 3.5 mm (1/8") gold-plated stereo plug Website: http://www.shure.com/PersonalAudio/P...pa_E2c_content |
#13 |
Thank you, Stephen
A very good idée, small, light and easy to carry. To be sure, I will get a second pair of headphones, Beyerdynamic DT -100/16B (16 Ohm) volki http://www.beyerdynamic.de/cms/Home....no_cache=1&L=1 |
