wide angle of standard lens FX7 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old April 29th, 2007, 09:10 AM   #1
I was wondering, how is the wide angle of the standard lens
from the FX7. Is it good enough to take good shots in a living room.
For example: When I have a small living room, and it is full of people
for a brithday party. How will the FX7's standard lens handle that situation?
Rob Willemse is offline   Reply With Quote
Old April 29th, 2007, 01:01 PM   #2
You need a wide angle lens for your small room.
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old April 29th, 2007, 01:38 PM   #3
So its angle is not that good as, for example, the Canon XH A1?
Has the FX7's standard lens a wider angle than most consumer
camera's have? Or can the FX7's lens angle be compared to that of the smaller consumer cams?
My old sony dcr-trv25e its lens angle was very bad, so I hope that the wide angle of the FX7 is better.
Anyone can explain a bit more how the angle is in comparison to other cams?
Old April 29th, 2007, 02:04 PM   #4
The FX7 has a wide angle of 59 degrees. The HV20s' is 50 degrees, while the Sony HC7 is 38 degrees.
Mike
Mike Burgess is offline   Reply With Quote
Old April 30th, 2007, 12:09 AM   #5
In focal length terms (35mm equivalents) the Fx7 is 37.4mm and the XHA1 is i believe about 34mm. So FX7 isnt as wide as the XHA1.
camera's have?
Yes it does. most consumer cams tend to be about 48mm, something like that. So FX7 is much wider than most consumer cams. But i think you'll find you need a wider-angle still for certain situations.
FX1/Z1 is about 34mm and so is XHA1, FX7/V1 isnt as wide. Wide angle lenses exist from Raynox - HD7000PRo, (step ring required), upcoming Raynox HD7062Pro 0.7x (62mm thread), and Century have a new 62mm thread 0.65x WA lens coming out. Sony have their 0.8x VCL-HG0862 lens.
Stu Holmes is offline   Reply With Quote
Old May 2nd, 2007, 02:26 AM   #6
Thanks for all the usefull info
