V1 legendary latitude: Black and Knee settings at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old March 14th, 2007, 07:43 AM   #1
Please explain me the theory behind it, cause my experiments yield inconsistet results: in order to get the maximum latitude, should I allow the High setting for the knee, or on the contrary - limit it to Low, to avoid white-outs? The Blacks should be stretched, I'm pretty shure...TIA!
Old March 14th, 2007, 10:48 AM   #2
There is an article here http://digitalcontentproducer.com/hd...titude_111106/ that I thought was useful.
Mark OConnell is offline   Reply With Quote
Old March 14th, 2007, 11:34 AM   #3
Thanks Mark - so it seems one should get the biggest latitude with Knee low, and Blacks stretched. This sounds logical; I'll check it tomorrow!
Old April 13th, 2007, 05:40 PM   #4
typical use for high knee setting
The longer I use my V1E, the better I like it; however there are a couple of things that seemed obvious at first sight, and when you know more they become no to so obvious at all...
Like this one: since - in order to get the widest latitude - we set black stretch and knee low, what is a typical use of other knee postitions (middle or high)? While changing the black compensation is very easy to see in the VF/LCD, it's not so easy to spot any difference with changing knee setting - what is the theory? And again, typical use for high knee setting?
Old April 13th, 2007, 05:58 PM   #5
HDV Cinema
Use HIGH on overcast days to add sparkle.
Use MED to keep constant setting for normal situations.
Old April 13th, 2007, 06:03 PM   #6
Thanks Steve,
With Canon, using Auto knee setting worked well for me, however it needed some time to "make up its mind"; how does the V1's auto knee setting perform from your experience?
