up and down moving picture from V1E on a TV at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old March 7th, 2007, 05:42 PM   #1
I have to write it down, nobody will believe me
This morning I got a HDMI cable and connected it with the HDMI out of the camera and the HDMI in of a new HD-TV.
Then I focused an about 2 meter distant object.
A full zoom shot, adjusted the picture, with extended focus, as sharp as possible. Then I went and watched the picture on the new HD-TV. Picture is super, but ..............
Camera stands on a tripod; head is firm, no wind, since it is indoor.
Although I stand about 4 meters away from the camera, the picture on the TV doesn’t stands still. It moves vertically up and down, up to one centimetre. Only vertically, not sideways.
First I thought it is an earthquake or the house is shaking. (haha)
After I switched off “Steady shot”, the picture stops moving up and down.
Ever heard of this?
volki
Max Volki is offline   Reply With Quote
Old March 7th, 2007, 09:54 PM   #2
Our V1P sure doesn't do that!
Me thinks yours be broken.
Old March 7th, 2007, 10:42 PM   #3
The manual of all cameras I have used that has image stabilization says to turn it off while using a tripod. Now you know why. There must be something that can fool image stabilization when the camera is perfectly still.
Old March 8th, 2007, 12:06 AM   #4
Shifting light frequencies/reflections, for one thing.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 9th, 2007, 08:37 AM   #5
to all
translation
That you have some flickering, if the camera stands on a tripod with >Steadyshot< on, is normal.
That was also the case with the older cameras; however this was not so noticeable. The Sensitivity of the cameras have improved in the course of the time, also image quality.
Generally the >Steadyshot< must be always be switched off, during use on a tripod, since minimum soil vibrations are passed on, over the tripod, to the camera and a conflict with the “Steadyshot” may occur
Sony PrimeSupport Europe
First thing I did, assigned a Button to >Steadyshot< on / off
volki
