V1E and Avid-Liquid? at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old January 21st, 2007, 09:09 AM   #1
Question:
is someone using a V1E with Avid Liquid (7.x) ?
and in 25P as well ?
thanks
volki
Max Volki is offline   Reply With Quote
Old January 21st, 2007, 09:21 AM   #2
Originally Posted by Max Volki
Question:
thanks
volki
I'm using the V1U and Avid LE7. Its no problem with 30p so I suspect its no problem with 25p on your side.
The only thing I've found so far is you can't set the file to progressive after ingest (it looks very bad if you do). You have to use the linear time-warp set to 100% speed and then select to STRONG combine on the fields setting. That leaves you with a true progressive. The down side to this is it puts you a generation down. Looks fine for the web which is where most of my work goes.
Chris
http://www.LandYachtMedia.com
Chris Medico is offline   Reply
