#16 |
Tony,
would it be a solution to shoot in 50i then deinterlace to make it progressive? How would that compare to 25p shots? Or am talking something stupid here?
Sony XDCAM EX1r, Canon 5DMkII, Røde NTG2, Røde NT1000, Røde Stereo Videomic, Sachtler DV6 SB on Gitzo 1325V, Steadicam Merlin, Omnitracker, Hackintosh 3.5Ghz Quad 8Gb RAM |
#17 |
Tony, it seems like when the blade of glass is not vertically straight-up got the most obvious "interlaced effect", was it very windy when you took the shoot ?
I am asking this bcs I realise that not only those few blade of glass in front of the swam got those effect, if you look closely to any area of the green, you can see those minor horizontal lines as well, not obvious bcs it is mostly green. In this case I don't think it is the problem of the encoding. Perhaps you can use the camcorder to take few pictures, see it gets the same issue or not. Or perhaps your tape is not clean ? sound silly, sorry if i am stupid again. |
#18 | |
HDV Cinema
An audience is going to the overall detail -- they are not looking for halos. This a nutty way to judge video. There's nothing wrong with your V1E. I wouldn't expect P to look exactly like I. The fact is the stair-stepping is aliasing. And, yes it should be worse on diagonals. To eliminate it -- one would need to lower overall detail. Not a good choice! Sony uses a setting of "5" for Cinema. I too want a detailed look so I wouldn't go lower than "5."
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#19 | |
Tony, does it happen only in a recorded material, or can you spot it when the camera is connected live to a monitor as well, ie. before going to tape? Steve, IMHO aliasing is more common with nearly horizontal, and not vertical, edges - just like the top TV set edge, heavily aliased in a picture posted in another thread on post-cure status of 25p... |
#20 | |
I think the halos are a matter of personal preference, mine is to reduce them where possible. The aliased edges on fine detail is another matter. I simply don't understand why interlaced should produce a beautiful anti-aliased image and progressive produce an over sharpened image with aliased fine detail. I personally would expect P to be near identical to I. Could you explain why you believe this not to be the case? Why does P footage have the aliasing while I footage does not? Piotr You have to be careful when monitoring on a 1920x1200 screen as that will induce stair steps if the screen changes the aspect ratio of the video. I don't have a way of monitoring live at native aspect ratio unfortunately so will not comment on live output. Anyway, I'll do a bit more fiddling but am coming to the end of my time off. :( Cheers TT |
#21 | |
#22 | |
#23 | |
#24 | |
Have you seen the difference between progressive and interlaced footage on a V1e? TT |
#25 |
It's never made logical sense to me that a cam said to be natively progressive would use the same native progressive sensor in a model that only supported interlaced output, the FX7. I think we've reached the point through semantics where you can call something anything.
#26 | |
#27 | |
Bad news I'm afraid. I have reshot my original test clip and the oil paint effect is still there along with over edgy lines. My original test clips didn't have enough high frequency detail to clearly show the effect hence my misplaced optimism. In a direct comparison between 25P and 50i the 25P material looks terrible. 50i never falls apart no matter what is filmed. I am sorry for posting duff information before I had chance to fully test out the camera. I am hoping Sony just forgot to upgrade my camera by mistake. Anyway my dealer is on the case....again. I am really impressed with their attitude now they are about to kick some a$$. When you get your camera back could you do some tests please? Sorry for posting duff info at the start of this thread... TT |
#28 |
Tony,
I'm so sorry to hear this. Of course I'll do my tests as soon as I get the camera back, but I must admit I dislike all this more and more. Could you please drop me an e-mail with the information who your dealer is in the UK? Thanks Piotr |
#29 | |||
Just my silly stupid opinion. |
#30 | |
And what you said might be correct too that they forgot to fix your camcorder before returning to you. I have similar experience dealing with Sony service center in Malaysia, my camcorder was like a ball being kick around few times before they really fixed the problem which is a month after few iterations. |
