Thread Tools
Search this Thread
24P correctly displayed via component output from the V1U
In the VASST DVD (I'll agree with Brian Rhodes that it's well worth V1U owners snagging a copy of this), it mentions that the component output of the V1U can provide 24P if shot with that progressive setting - am I correct in thinking that component output correctly displays 24P recorded with the cam?
I'm unable to test this as I don't have the necessary equipment (I'm on travel), but I believe the component carries the pulldown, or in other words, 50i/60i, not 24p.
Easy to test, just don't have a component monitor with me.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
It's difficult for me to tell since I don't have either the experience of something else to compare it to, but the 24P footage looks different than the 60i when I output it on my HDTV using components from the V1 - but then again, the captured streams (via FCP) also look different than each other.
One thing to consider is that some displays can remove the pulldown. My Mitsu has that ability.
Chris
http://www.LandYachtMedia.com |
#5 |
DSE,
Can you check this out? It would be good to know if the component out provides 24p without pulldown. Then, in theory, one could capture using component out and an outboard card to 24p, correct? I'm not really sure how to tell looking at the output of the component feed if it does or not. Thanks! |
#6 |
Today I was in a store asking about the new 1080p LCD TVs that was on display and said that when I came in next with my soon to be brand new V1 I'd plug it in to see the 1080p and he said:
"We currently have no cables in Australia that transfer a 1080p signal." He said that to transfer 1080p you need at least an HDMI-3 cable, which will (when they become available) cost AU$599. He said any other HDMI cable transfers a maximum of 1080i. Does this sound right to everyone else? And here's my next question: Does the V1 ship with its own HDMI output cable, and is it HDMI-3? |
#7 | |
#8 |
Just FYI, you can pick up new HDMI cables on eBay for about $10 (not 1.3 cables, mind you). No need to pay an exorbitant price. I have used one with my HC3 with no problems.
