V1 25p issues (combined threads) - Page 9 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old December 15th, 2006, 04:57 PM   #121
Now I am seriously worried. My V1 arrives on Monday. Maybe I will use same day delivery - as in back to the store...
Zsolt Gordos is offline
Old December 15th, 2006, 05:02 PM   #122
Hi Spot, the only thing I managed to find within the small session this afternoon was setting the shutter speed at 1/50 second (and activating the 25P modus). To have a nice average framerate for 25P footage. I didn't touch any other functions in the camera as it was basically coming straight from the box. Could this cause the image/gain problems?
Peter / Orphic Film
www.orphicfilm.nl and www.myspace.com/orphicfilm
Peter Sieben is offline
Old December 15th, 2006, 05:07 PM   #123
Here is one videoclip from the footage (in HD WMV9 format):
http://www.videomontageforum.nl/ubbt...?Number=104504
Peter / Orphic Film
Old December 15th, 2006, 05:19 PM   #124
Absolutely! Most likely, in fact.
To correctly set the camcorder for manual gain, select the menu button.
Now select Camera Setup.
Now scroll down to Iris.
Set Iris to "Iris." Not Iris-Auto Shutter, and not Iris Auto Gain.
Scroll back up to exit.
Select menu again to exit the menu.
Now your gain is manual, and displayed in the preview window.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old December 15th, 2006, 05:23 PM   #125
Thanks Spot. Within two weeks I might be able to do a second try and will alter the settings as you described. Weird that the standard settings are not doing the camera any justice.
Peter / Orphic Film
Old December 15th, 2006, 05:30 PM   #126
But they are. You didn't use the standard settings, you went into the menu and modified the camera. If you're shooting manual, then the manufacturer expects you've looked into the menus and set it up for manual use. If you want "easy" mode, put the cam in the Green Box/Easy mode and shoot that way. Whether it's Sony, Canon, Panasonic, JVC, or whomever, I'm not sure how they could have a "de-suck" setting that would say "well...he's got this in manual and that in auto, and it will look bad, so we'd better modify this to prevent suckage..." ;-)
Old December 15th, 2006, 06:10 PM   #127
I had the chance to shoot some 25P footage with the Z1 PAL camera this afternoon.
Peter: you said the camera was a Z1 in both the title of the thread and in your post. Did you mean V1???
Boyd Ostroff is offline
Old December 15th, 2006, 06:12 PM   #128
its quite likely a typo error as Z1 cannot shoot 25p.
Old December 15th, 2006, 06:15 PM   #129
a V1 !
Sorry guys, yes it was a V1 I hold this afternoon.
Peter / Orphic Film
Old December 15th, 2006, 06:27 PM   #130
Thanks Peter. I have changed the title of the thread to correct this.
Old December 15th, 2006, 06:49 PM   #131
Wow are those bad. While this may be an easy fix I wonder what the heck SONY was thinking by letting this get past quality control. I mean even a two year old would be able to tell that those images just are not right. At least JVC with the split screen issue had a valid technical reason for doing it the way they did. You could still use the camera but you had to be carefull.
Some of these images to me kind of look how a really bad flat panel HDTV will try to upsample and sharpen footage and it comes out with this very odd look. From a distance it looks ok but up close it looks like poodoo.
Thomas Smet is offline
Old December 16th, 2006, 01:48 AM   #132
Guys the oil paint problem is magnified with the gain up.
The oil paint efect is cause by an over aggressive noise (high frequency) filter. Any high frequency detail or noise in an image is smoothed out.
Come on, let's not for get Sony know about the problem and are working on a fix.
Yes, the 25P mode is dreadful but for only the time being.
IT'S GOING TO BE FIXED.
TT
Tony Tremble is offline
Old December 16th, 2006, 01:51 AM   #133
It doesn't look that good!!!!
Old December 16th, 2006, 02:02 AM   #134
TT
Tony, are you certain about this? You seem to know more than you share :)
I dont mind that, I just dont want to end up without a fix.
Old December 16th, 2006, 02:04 AM   #135
I am not holding anything back. There is nothing more that can be said. Sony know about the problem and it will be fixed...
TT
