#16 |
MPS Digital Studios
We're shooting some stuff with the V1 while we make my film 9:04 AM and thus far, it's pretty cool. No S video input/output, though...
heath
My Final Cut Pro X blog |
#17 |
no S-video output
No s-video output at all, or just the supplied A/V cable without an s-video? With HC1, for instance, the supplied A/V does not contain s-video, but it is actually output and you can get it using the A/V cable version as per the A1... So, did you check it?
#18 | |
I believe if this is the case, it will work with S-Video perfectly fine. It's just a matter of wiring and should work if you have the s-video cables. |
#19 |
MPS Digital Studios
No S video output. Having said that, it's a great camera so far!
hwm
#20 |
Contributor
color correction.....................No..........................Yes
What does that mean in relation to the Z1? No color correction? |
#21 | |
http://bssc.sel.sony.com/Broadcastan...-V1U/spec.html A/V OUT jack, 10-pin connector Composite video: 1 Vp-p, 75Ω unbalanced, sync negative Y: 1 Vp-p, 75Ω unbalanced C: 0.286 Vp-p, 75Ω unbalanced Audio: 327 mV input impedance more than 47 kΩ, output impedance less than 2.2 kΩ Clearly, the Y/C signals are there; so it's just a question of the right cable (the one with s-video is needed) |
#22 |
But who cares about S-video ?
Anyhow, you are going to read the stream from the tape ( or through some Firewire) and edit it. For Direct viewing, HDMI/DVI and YUV are much netter .. SO if it has one S-Video it should never be used... Could we go back to the original question of this thread ??? |
#23 |
Contributor
The originnal question, Is the V1 worth it over the Z1?
I'd say if you don't already own a Z1 and you want 24p more than 1/3" chips, then the V1 might be a better deal because it's significantlly cheaper. But if you already have a Z1, you can use Nattress' effects of DVFilmmaker to get to 24p when you edit. If I were going to buy a camera today and both were avaialble, I would definitely consider the V1. |
#24 |
I would buy the V1 over the Z1.
#25 | |
MPS Digital Studios
heath
#26 |
10 pin connectors
This seems to be the latest fad in Sony cameras. In fact, I just bought a 10 pin a/v cable today for my HC3. It provides BOTH s-video and composite video as well as two rca audio plugs. These cables run between $40 and $70 depending on length (1.5 m and 3 m). So it sounds like you can access s-video from the V1.
#27 |
MPS Digital Studios
Hmm, interesting. Maybe that's how we'll connect it to S.
hwm
#28 |
MPS Digital Studios
Getting back to the topic at hand...here's a still of some Z1 footage from my film, color corrected and at 1/2 res (and 23.98 fps):
http://www.904am.com/photos.php?pic=23 I think the Z1 is still a great, great camera. I'll have more thoughts on the V1 in a few days. So far, small things leading up to something cool while we're shooting the movie. heath
#29 |
Thanks Heath! It is really cool that someone is shooting with the camera. And not just sample footage, but test it for movie production in the middle of a production. That will be a good test for the camera.
#30 | |
MPS Digital Studios
For the record, I love the Z1, DVX100a/b and in the higher-end realm, the F900 from Sony. Those are the cameras that have been good to me. heath
