#16 |
It is my understanding that whatever settings you use for 24p or 30p judder and smear are fighting eachother. Techniques like using depth of field to defocus areas that are moving quickly, and focus only areas that are moving slowly relative to the camera minimise this and an optimum shutter is around 1/48th. Faster and the result judders much more, like a strobe effect, slower and things smear too much.
60p by the same math should produce much smoother motion that stays sharper with a 1/120th shutter. Since small chip cameras don't have as narrow a depth of field, increased frame rate is the way to go for higher quality and ease of use. Just my impression of the situation. |
#17 | ||
Barry Wan Kenobi
Are you asking if there's a noticeable difference between 30p and 60p? Night and day different. Are you asking if there's a noticeable difference between 60i and 60p? Not too different, both impart a similar "feel". But the point is: 60p is irrelevant on this camera, there's nothing you can do with it, it's for internal processing only. Apparently they're scanning the CMOS chip progressively, so in order to create its 1080/60i signal it has to work internally at 1080/60p, then it slices the 60p frames into interlaced 60i fields (same as the HVX does). The Canon and Z1/FX1 don't work that way because they use interlaced chips and scan them interlaced in the first place. 720/60p shot and played at 60p isn't for slow motion, it's for "reality"; watch the Super Bowl or the NBA Finals or anything like that and you'll see it in action. Quote:
Plus this V1 has some other interesting aspects, such as its slow-mo mode where it shoots 240 fields per second and plays 'em back at 60 fields per second for 4:1 slow motion, plus it has uncompressed HDMI output and apparently they've introduced an HDMI capture/edit card, so that's an alternative to HD-SDI. And there may be more surprises in store; I still haven't figured out what the USB port is for. |
#18 |
My guess is that the USB port is most likely for moving still images and camera settings off of the Memory Stick. Sure you can just take the Memory Stick out and put it in a card reader... most Sony Vaio laptops and desktops have a reader built in... but I've noticed that the majority "megapixel" camcorders with still photo capability do in fact have a USB port included for this very purpose (the exceptions being the Canon XL and XH series).
#19 |
So is 1/3 ccd suppose to be the equivalent of 1/4 cmos sensors? What are the positives/ negatives of using cmos chip instead of ccd chip?
#20 |
Barry:
Thanks for the primer. I didn't realize HD was actually broadcasting 60p.
Chris J. Barcellos |
#21 | |
Barry Wan Kenobi
#22 | |
I'm not into slide rules and the math. I get the same results from any number of tests with the camcorder, and until Sony shows me something different... I'm accepting what Fuji, Sony, Grass Valley, and other people I trust on the method in which the resolution is measured. No matter how you look at it, I've shot a standard series of res charts with this cam vs every low cost HD cam out there including some of Sony's lower grade consumer cams (including the HC3) and it is the highest of them all by a fairly discernable grade. Boyd and Michael saw some of those images that I captured today. And frankly, that's all I care about. What the res chart that I can work with from my own eye is all I need, coupled with the images that I've captured in a variety of settings. The camcorder (like a few others) processes internally at 60p. The pixels are processed internally as 4:2:2. None of that matters to me unless I need a supportive argument in favor of one cam vs another. it's about the picture. Nothing more. And nothing I own outside our relatively elderly CineAlta produces pictures as nice as this cam does. Additionally, Nate is correct. In my hurry to convert the Para2, I apparently managed the flags incorrectly (Nothing currently supports the correct pulldown removal in HDV) and I need to change that out. It's not appropriate to capture this via my Xena and process it as 4:2:2 from the cam, because that's not a "common" workflow for anyone, and the flags can't be inserted (at this time) in post anyway. If I can figure out a means of watermarking the raw files, I'll do that.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#23 | |
#24 |
You're right. Its just this CMOS chip is new to me and caught me off guard.
#25 |
Thankyou for the reply Douglas,
I of course agree that the actual visual performance is everything, but sometimes the internals give a clue as to how defects are being hidden. If you happen to have the camera out again with the resolution chart, would you consider estimating the resolution of a 45 degree diagonal please. |
#26 |
There's a slide of a resolution test which they showed at the presentation, and Chris has that along with a bunch of other stuff. Please be patient, I'm sure he will put it online when he has a chance but I know he's been busy so it may take a few days.
#27 |
I'm just waiting to hear back from Sony that it's okay to put all of that online.
#28 |
Thanks Boyd, Chris,
If this is a horizontal/vertical resolution test then it isn't the information I am after. On a normal sensor a 45 degree diagonal will have a resolution exceeding that of the H and V directions by a sizable amount. On the clearvid this will be lower. I would like to know how much this aspect of the picture suffers. I do notice that on the V1 page the comparison uses only a part of the image that has just vertical and horizontal information, square bricks, a window. I am most concerned about the performance on the diagonals. |
#29 |
Time Lapse/Shutter Angle?
Douglas mentions that they shot time lapse. I can't find mention of this anywhere on the Sony site. Also, can the user change the camera's shutter angle as well as the shutter speed?
#30 |
Yes the V1U has interval recording for time lapse video. I'm not sure about changing the shutter rotation angle, but I do remember from the video that you can set the shutter display indicator to show in seconds or rotation angle/degrees. The focus display can be set to feet or meters.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese |
