#16 |
60p! Did I read that right? I figured 30p would be the highest. How in the heck would you ever get 60p out of the camera though? Will Intensity capture 60p through HDMI?
Could Sony have meant 60i, not sure how they could have messed up their own press release though. Perhaps it can capture HDV in 60p to that hard drive unit. |
#17 |
whoa...is this THE ONE?? dang, and here i thought the canon XH series was gonna be THE ONE...with the trade-in program, this is gonna be hard to resist! canon, quick, give me a reason!
how great to have these sorts of "problems" in choosing from such magnificent cameras at these prices... |
#18 |
60p should mean some great slow motion shots.
Chris J. Barcellos |
#19 |
#20 |
Don't see them touting 60p.... could have been error in release ??
#21 | ||
#22 |
MPS Digital Studios
I think the camera does 24p, 30p and 60i because this site
http://bssc.sel.sony.com/Broadcastan...V1U/index.html isn't saying 60p. heath
My Final Cut Pro X blog |
#23 |
Here's a quote from the site Heath mentioned:
"the HVR-V1U supports 24p (progressive) scan, the frame rate of film and 30p (progressive) scan modes, in addition to typical 60i" |
#24 | |
Quote from the above site: "Processor, the HVR-V1U supports 24p (progressive) scan, the frame rate of film and 30p (progressive) scan modes, in addition to typical 60i." So it's 60i, nmot 60p, and as such the Sony press release here : http://news.sel.sony.com/en/press_ro...ase/25017.html appears to have been badly worded, as it strongly implies 60p : "Sensor system natively captures progressive images at 24P, 30P or 60P, while maintaining full 1080 HDV resolution" Bit unusual for a Sony press release to get it wrong on basic stuff like that. |
#25 |
#26 | |
Barry Wan Kenobi
#27 | |
Barry Wan Kenobi
#28 | |
shutter-speed range in SmoothSlowRecord mode is 1/250th - 1/2000th, not-user-selectable (unless as you say, they've tweaked that mode siginificantly). |
#29 |
All the documentation on that Sony page seems to indicate that everything is processed at 4:2:2 using EIP, is this correct?
Or will it still be recorded to tape at 4:2:0 (DV limitation). And furthermore, has it been confirmed whether or not we can bypass that DV limitation by recording straight to the HDD? |
#30 | |||
Barry Wan Kenobi
According to the chart on their website (http://bssc.sel.sony.com/Broadcastan...EipSignal2.gif) the signals start on the chips and go through a "Sony original interpolation Process" to become 1920x1080. Then, before any output occurs, it goes through a "Resolution Conversion Process" to become 1440x1080. Now here's where things get interesting: it shows that the resolution conversion process yields 1440x1080ix4:2:2, which goes to the component outputs and to the HDV compression engine. HDV will process that into 4:2:0 for recording on tape or onto hard disk, but what about that "component output"... on analog component output it's not any different than any other camera out there, but what about HDMI? Is that going to be an actual digital 1440x1080x4:2:2 digital HDMI signal? If so, will someone develop (or has someone already developed?) an HDMI->HDSDI converter box to allow uncompressed 4:2:2 digital HD recording? |
