2 microphones X 1 audio at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old August 1st, 2010, 10:46 PM   #1
I have a V1U and 2 wireless microphones, but when I make the interview, the sound from the channels, to be separeted.
How make the interview with the channel 1 and 2 linked ?
Clecio
Clecio Mayrink is offline   Reply With Quote
Old August 2nd, 2010, 10:26 AM   #2
By linked I'm assuming you mean mixed together into 1 audio channel. There are 2 ways to do that. 1. you can send both mic signals into a separate mixer then into one of the V1U channels. 2. you can combine and mix them when editing. The benefit of 1. is that you can control the mix on the fly and have good clean audio. You could try to split the audio feeds from the mics and go into both channels at the same time, but that may induce problems and loss of signal strength. The benefit of waiting till you edit is that it gives you maximum control over the separate audio feeds.
David Stoneburner is offline   Reply With Quote
Old August 9th, 2010, 07:11 AM   #3
Thanks David,
I understand now.
I control the volume and add the two channels in editing software
Clecio :)
Old August 10th, 2010, 09:05 AM   #4
Equal Opportunity Offender
That's what I do. Record separately and put them together in post ... giving the most control possible.
Andrew
