V1 not detected by Mac - Page 2 at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old July 12th, 2009, 01:01 PM   #16
If your LCD is flashing DV rather than HDV then obviously your cam is in DV mode, so an HDV project won't see it. You still haven't told us what your project settings are so there's no way to know for sure.
You say your footage was shot in HDV, but your cam is telling you otherwise. Are you sure? Did you mix DV and HDV on the same tape? Is VCR HDV/DV set to HDV? Are you sure i.LINK CONV is OFF? You're sure the cam is in EDIT/PLAY mode? What's your Easy Setup for FCP?
Pages 75-77 of your V1 manual.
Old July 13th, 2009, 10:21 AM   #17
The footage was shot in DV, not in HDV. I'm sorry if I stated otherwise. I'll post project settings when I get back from work.
Chris Barrows is offline   Reply With Quote
Old July 13th, 2009, 11:35 AM   #18
Chris,
I was under the assumption that you were working with HDV footage. With DV footage, then that would change most of the settings that I had previously posted, and may explain why the camera continues to not be recognized by your mac.
I haven't really used my V1U for DV capture and export, so I don't have any experience with it. However, I may be able to try some previously captured DV footage from my old trusty TRV900 and pop the tape into my V1U and see if I can export it or not.
Did you capture in standard DV SP or DVCAM? It probably shouldn't make any difference, but I know all of my content is DV SP, so any test that I would perform would be with that content.
You should also connect the camera, and see if it shows up on the firewire bus, via the "About This Mac", then "More Info...", then check the "Firewire" bus and see if the camera shows as connected to the bus. Ensure that the camera is connected and powered via previously posted process, and I would not have FCP started until after you have verified the camera shows on the bus. If you don't see it, I would refresh the system profiler, and if you still don't see it, perform one more reboot (leaving the camera on and in VCR mode), and see if it shows up. Mine was a little temperamental the first couple of times, but always shows up now.
Jeff Allen is offline   Reply
